ZTR Mower Engine Surging and Dying
/ ZTR Mower Engine Surging and Dying #11
No problem hope that gets you mowing again.
One thing on those caps with the hole in the center. They will suck in water when the tank is warm and a cool rain shower comes along. As the tank cools, a vacuum pulls water into the tank. I finally went to a side vent cap. They also have those caps with the thumb screw that you release when using and close when finished. When my Kohler's would not run, I just knew there was water in the gas.
Where did you find the replacement caps?
/ ZTR Mower Engine Surging and Dying #13
Most of the larger machines use the 2 in caps, and just about anyplace will have a cap for the models they sell, or you could look on-line. I bought things when I found something I wanted, and needed. Take your cap with you when you are shopping, and tell the guy at the counter exactly what you want, He may give you different options.
/ ZTR Mower Engine Surging and Dying #14
There was some discussion over on Lawnsite.com that this was a common issue with some of the JD ZTR's. I didn't have a JD at the time and didn't pay too much attention to it. I think the recommended solution was to replace the cap. If I come across the thread I will post it.
iDrive TDS-2010H...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2014 Ford F-150 Pickup Truck (A59230)
2014 Ford F-150...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
