ZTR Mower Engine Surging and Dying
/ ZTR Mower Engine Surging and Dying #11
No problem hope that gets you mowing again.
One thing on those caps with the hole in the center. They will suck in water when the tank is warm and a cool rain shower comes along. As the tank cools, a vacuum pulls water into the tank. I finally went to a side vent cap. They also have those caps with the thumb screw that you release when using and close when finished. When my Kohler's would not run, I just knew there was water in the gas.
Where did you find the replacement caps?
/ ZTR Mower Engine Surging and Dying #13
Most of the larger machines use the 2 in caps, and just about anyplace will have a cap for the models they sell, or you could look on-line. I bought things when I found something I wanted, and needed. Take your cap with you when you are shopping, and tell the guy at the counter exactly what you want, He may give you different options.
/ ZTR Mower Engine Surging and Dying #14
There was some discussion over on Lawnsite.com that this was a common issue with some of the JD ZTR's. I didn't have a JD at the time and didn't pay too much attention to it. I think the recommended solution was to replace the cap. If I come across the thread I will post it.
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2018 FORD F-250 XL...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
405 (A52706)
405 (A52706)
