Size of hexagonal socket bolts on BX grill guard
   / Size of hexagonal socket bolts on BX grill guard #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
Hi group.
I want to stop on the way home from work today to pick up a hex key socket or a set of them so that I have one that is large enough for the bolts that hold the grill guard on the BX tractors. Does anyone know the size of those bolts offhand, or at least know if they're either SAE or metric?
Thanks
   / Size of hexagonal socket bolts on BX grill guard #2
I'd say there most likley metric. I like the allen wrenches with a "ball" on the end of them. It allows you to use the tool at an angle.
Thanks for the guess, but I'm wondering if anyone knows. Is that a GN in your avatar?
   / Size of hexagonal socket bolts on BX grill guard #4
The bolt is metric. The hex wrench size is 10mm, which was the largest size in my metric set.
The nut on the inside requires a 17mm wrench.
Hope this helps,
Jim
That's outstanding. Thanks Jim. And I was just walking out the door. Now I can stop at Sears Hardware on the way.
   / Size of hexagonal socket bolts on BX grill guard #6
And the first time it's removed it might take a surprising amount of muscle!
   / Size of hexagonal socket bolts on BX grill guard #7
It's a monte ss, I've owned it for 11 yrs. now. It's a fun street/strip car, It runs 7.80's in the 1/8th
   / Size of hexagonal socket bolts on BX grill guard #8
Hope this helps,
Jim
Mine dont take a wrench,i welded them to the frame so i didnt have the hassle:)Quick job to remove it now without standing on my head:D
ALAN
Excellent! I have an 87 Cutlass that I [honestly!] estimate at being a mid-13 car in the 1/4 mile. Of course, this was before it sat in my back yard not being driven for three years and now needs some work... It has an Olds 403 (small block) bored to 409 with all the typical goodness in it. I love love love the G bodies.
   / Size of hexagonal socket bolts on BX grill guard #10
The grille guard on the Kubota BX25D is held in place using (4) HHCS M14 x 50mrn bolts, nuts, and washers.
COOPER'S CRAFT METAL SIGN (A58374)
COOPER'S CRAFT...
2015 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52709)
2015 CATERPILLAR...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58216)
1982 SHOP BUILT...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
JLG 15 MVL MANLIFT (A58216)
JLG 15 MVL MANLIFT...
JOHN DEERE 3PT HITCH BACKHOE ATTATCHMENT (A58374)
JOHN DEERE 3PT...
