Enough power to pull???
/ Enough power to pull??? #1
shade2u2
Gold Member
Ohio
NH TC33D
I'm leveling/smoothing some land to prepare to seed. My friend let me use a homemade "drag" made of 8" I-beams that are welded into a box about 3'deep X 10' wide & the thing weighs between 500 lbs. I attached it to the draw bar of my TC33D by cables & it does a fantastic job. BUT it bogs down my tractor at times when pulling up grade while the "box" has quite a bit of dirt in it (probably adds another 200 lbs). I've never plowed or done significant ground engagement type work. Is this thing too much for my tractor?
/ Enough power to pull??? #2
Are you in low gear? and at PTO RPM? if so, you've got too much of a load. If not, rev it up and use low gear. I bet you have alot more than 700#'s behind you. My 6' box scraper weighs twice that when it's full of dirt or gravel and my L3710 never complains.
I am in low, 4WD, and max RPM. You're probably right about the weight. The contraption probably weighs 600 lbs after some re-calculation by the owner. It is only 8' tall so the dirt weight probbably doesn't exceed 300 lbs. I guess the big thing is the ground resistance across the 10' span. Maybe I let the dozer drag this thing or use on only the level areas without grade.
Here's a picture of this "drag"...
Sorry - it was getting dark...
As you may be able to tell, it was to wet to do any work today...
/ Enough power to pull??? #5
<font color=blue>... I guess the big thing is the ground resistance across the 10' span...</font color=blue>
Yep... /w3tcompact/icons/smile.gif
I think my JD would have to strain some in certain areas with that...? /w3tcompact/icons/blush.gif
/ Enough power to pull??? #6
shade2u2,
You might try flipping the thing over, it would be less inclined to take such a bite. You also might try rigging it on a shorter cable if possible, to provide some vertical lift under load.
Al
/ Enough power to pull??? #7
Looking at the leading edge and the way dirt seems to pile up, it appears the bottom I-beam shape is actually digging in like a loader lip. That's probably good, but will surely make much more resistance than just having a flat vertical lip scraping across the top of the ground. If the front lip was a "J" shape, it wouldn't be nearly as tough to pull. Of course, your friend might not want to take a torch to his implement just to check out my theory. /w3tcompact/icons/laugh.gif From your picture, it looks like it does a very nice job.
/ Enough power to pull??? #8
Well, if that thing is 10' wide, 3' deep, and 8" tall, then it holds about .7 cubic yards of material. If your dirt is 2500lbs per cubic yard, then when it's full, it would be about 1800 lbs. I also question that the weight of that is only 600 lbs. My little 4' boxblade weighs almost 500#...
/ Enough power to pull??? #10
Sorry fellas. I just saw the title for this old thread and couldn't resist. :D :D :D
No way hed move that thing with the chains hooked that way! HST is the way to go with something like that, but the chain is going to have to be a lot lower on the loco with such a light tractor.;)
larry
/ Enough power to pull??? #11
SPYDERLK,
You ain't seen nothing yet. Just wait till I get my Kubota back from the chrome shop mafia guys. They're a holding my baby hostage until I pay the bill for the chrome stack and canopy they installed. Next payday I'm going to pay them off and then hook her up to an F-18 aircraft here at Ft Leonard Wood and I'm gonna drag that airplane a 100 yards ! :D :D :D
And yes I'll lasso the chains a bit lower than I did the locomotive. ;) ;) ;) The photos are coming soon I promise !
MissouriThunder
2021 Chevrolet Silverado 2500HD Service Truck, VIN # 1GC2WLE77MF197329 (A61165)
2021 Chevrolet...
5x10 Utility Trailer (A61165)
5x10 Utility...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63118)
PENDING SELLER...
2017 Case CX145D (A60462)
2017 Case CX145D...
