BX24 taking back hoe off is getting old
   / BX24 taking back hoe off is getting old #11
IMHO, having a dolly is the way to go. I made a couple out of pressure treated wood: one for the BH and one for the 3PH chipper. When the BH is on the tractor, I put the 3PH snow blower on the dolly and wheel it out of the way.
Like others, I lift the stabilizer arms all the way up and use a bungy cord to keep them from settling down.
This past winter it sat for 5-6 months with no problems.
   / BX24 taking back hoe off is getting old #12
Mine droops over time ... I usually simply put a cinder block under the base and that does the trick
   / BX24 taking back hoe off is getting old #13
yeah dolly does sounds like its the way to go but I haven't seen a dolly that can go off-road yet. :rolleyes: I have a blacktop driveway I can unload the BH onto the dolly if needed, but needs to be transported somehow over a lawn/bumpy trail to resting spot. I assume the dolly would need to have lawn type of tires with a tow hitch to make it compatible for my needs.:eek:
I asked eons ago about the back hoe drooping while on tractor while it sat and everyone said it's normal. It's doing the same while off the tractor which I sort of expected. Except stabilizers went up instead of down and bucket is curling instead of uncurling.
   / BX24 taking back hoe off is getting old #15
The stabilizers are going up? :confused:
I can understand the curling of the bucket, if it's resting on it, but the stabilizers going up is bizarre!
   / BX24 taking back hoe off is getting old #16
The stabilizers are going up because they are supporting the weight of the backhoe when it isn't on the tractor.
You got it, it's flat as a pancake on the floor. I just hope the hoses still reach to get it back up.
   / BX24 taking back hoe off is getting old #18
radioman - No idea if this will help or not for your situation but I use the BXpanded BH dolly on a large piece of thick plywood on the grass where it currently is sitting. I then tarp it with a motorcycle cover. Now that I have a new garage, I will be putting the BH on the dolly inside after I get a proper ramp to drive up on.
   / BX24 taking back hoe off is getting old #19
You can always get a couple more tractors and never have to take the backhoe off!!!!!:D:D:D:D:D
   / BX24 taking back hoe off is getting old #20
:eek:
:p shaking my head. no thanks- I wouldnt want to end up like lbrown
Kubota M108S (A53317)
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
2371 (A58376)
2371 (A58376)
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
