Another JD vs Kubota question
/ Another JD vs Kubota question #1
Adirondaquer
Ford 1600
So I went to the Kubota dealer today to look at a nice barely used BX24 and of course the guy before me ended up buying it.
So now they walk me over to the new BX25. All shiney and pretty. Lets me sit on it and play with the gadgets.
After I was done salivating, they took me in to talk prices.
The machine with the backhoe attached came out in the high 16K and add on some taxes.
The used '06 BX24 sold for 13.5k and now I find myself considering the new one and paying the extra three thousand after they told me it would be 0% financing for 3 or 4 years. What ever I wanted.
Forced myself to walk out with the paperwork in hand to think it over for a week.
On the way home I figured I'd stop at the John Deere dealership. Same sized machine, JD 2305 with 200CX CP loader and 260 backhoe and with the three pt. hitch (that the BX25 didn't have) and extras (some sort of easy quick hitch connection features and ballast kit) added up and total was only $1000 more than the Kubota.
I had anticipated JD being at least 2k more.
So if I want the 3 pt. hitch for the Kubota the difference is really around $700 I am guessing.
With all this being said, would you consider paying the extra for the John Deere?
Or do you think Kubota has a better quality machine?
Does anyone know what differences there might be?
Thanks again for the help you guys bring.
/ Another JD vs Kubota question #2
They are both good machines. Did you try out the JD also? I would go with the one that feels the best to you. If you are comfortable with the Kubota save yourself some money. If the JD is more comfortable and will do what you want it would be worth paying the difference. There are other decent models available from other companies if you wanted to expand your options.
/ Another JD vs Kubota question #3
Can only speak from the Orange side of the fence...I'm VERY happy with my BX23.
Don
/ Another JD vs Kubota question #5
I would strongly recommend you think hard about the 3pt hitch, I would almost guarante you will want it at some point. You will really limit your tractor uses and resale value without it.
/ Another JD vs Kubota question #6
I have to agree to try the JD out. For me, the rocker pedal Kubota uses would be more difficult than the two pedals the JD uses, but that is a matter of personal preference. Also, Landpride sells a quick hitch as well, which Kubota will include in their financing deals. If you are going to have multiple rear mounted implements, a quick hitch is one way to simplify hookup; there are others as well. If you do get the quick hitch, either JD or Landpride or others, make sure that any implements you get will work with it. Some implements, like a post hole digger, will not work with it at all, and some brands and models of other implements will not fit without modification. Good luck in your search.
/ Another JD vs Kubota question #7
The MASSEY 2410 with 72month 0% financing might be a better option .
/ Another JD vs Kubota question #8
*I'm VERY happy with my BX23.
Don
*Funny U should say that .
I just came in from from my mowing my back yard and was thinkin while mowing = out of all the Sub Compacts out there I'm sure glad mine is a BX 23.
*You will really limit your tractor uses and resale value without it.
*I agree but as for the R V he could aleays purchase and install the 3 point prior to offering the tractor 4 Sale.
/ Another JD vs Kubota question #9
are both dealers good to work with? I picked my JD over the kubota due to the dealer in the end
/ Another JD vs Kubota question #10
You definitely need to get the 3pt thrown into the deal. You will regret it if you don't. As to which color to buy, well you can only make an educated decision by getting on both machines and playing with them. I spent over two months going to the same four dealerships and playing on the Kubotas, John Deeres, New Hollands and Masseys until I felt like I could make a good decision. I thought I had to have a green one but as you can see by my sig the big orange won out soley on DEALER, DEALER, DEALER, perceived capability, comfort oh and did I mention DEALER with price having the LEAST amount of influence. I know I made the right decision for me :p
Troy
/ Another JD vs Kubota question #11
I would get the Deere.:)
/ Another JD vs Kubota question #12
For me, the rocker pedal Kubota uses would be more difficult than the two pedals the JD uses.
I disagree completely with this opinion, and granted mine and G-W-be are just that, opinions so here's mine. I came from a JDX485 to a BX. The JD had the side by side forward/reverse pedals and unless I looked down, I very often tapped the reverse instead of the forward pedal. I owned the machine less than a year so maybe I would have gotten use to it, but never did in that time period. And with the mower kill switch in reverse, it drove me nuts when I just tapped that pedal by mistake and cut off the PTO. With the BX, what could be more natural than step forward to go forward, step back to go in reverse.
/ Another JD vs Kubota question #13
There are no lock out or back up swithes to worry about on 2305 unless they just came out with it this model yr. I will diagree alsoabout the pedals if you couldn't get to side by side how can you get use to using the rocker one on Kubota .
Seems like you would always be putting tractor in forward or rev by mistake if just setting there. I know that would hurt my ankle I had broken yrs ago. just rocking my foot back and forth
also if buying a fel loader or front plow or using the hyd line for mmm why would you what to sit with your arm stretched out about all the way (on MF or Kubota) when you can sit with your arm by your side and use fel,or frt blade or mower.
/ Another JD vs Kubota question #14
Don,t limit yourself to only 2 choices.I would also look at new holland,massey,kioti and a few others.IMHO,what to look for is a dependable tractor with great sales and service and what ever fits your needs the best.coobie
/ Another JD vs Kubota question #15
I know what you are goin thru. I had settled on an orange tractor,from resarching this and other forums,talking to Kub owners,etc. Looked for used ones in the BX size,most were 12500 - 14000 for 2 to 4 year old ones. But wound up with a green one,2305 brand new. Got it from a dealer 40 miles away-local green guys(15 miles) wanted 500 MORE for a 2 year old ,200 hr 2305. The local Kub dealer wanted 6000 MORE for a 1 year old BX24 than what I paid :eek:
One thing I really like - and mentioned by someone else- is the loader control right at your side. No lifting arm to reach it,just move hand to right and its there. plus the lock out for control,so if need loader to keep at a set point cant accidentally hit stick and drop whatever you are lifting. dont know if Kub has that or not.
But this is my first TLB so time will tell if I made right choice.
/ Another JD vs Kubota question #16
As others have said, not getting a three point hitch will be a mistake. Whatever brand you get, make sure it has the 3PH!
I have the side-by-side pedals on my 4200 and the rocker pedals on my L130, and I like the side by side much better. Yes, I have on occasion tapped the reverse pedal accidentally with the 4200; but I find that style easier to control than the rocker pedal system.
There are a number of Deere dealers to choose from in my area; though one outfit has pretty much of a monopoly on Deere along the Front Range and plains of Colorado. There are two Kubota dealers about equidistant from me. One is a pain to get to, and the other wouldn't give me the time of day when I was shopping. Be sure to factor in dealer support!
/ Another JD vs Kubota question #17
Ironically I'm in the same boat. I'm trying to do my research hence why I recently joined on here.
One thing I would like to know and something you might ask as well is: are there differences in costs for repairs and parts? For example I have a Volkswagen Jetta TDI and I can only buy the oil and filter from the dealership and no telling what the costs for parts will be when I need something repaired(knock on wood). So are foreign tractors the same?
You also still hear, "you are paying for the green paint". I've also heard that Kubota makes a better product. Of course both could be old adages that are no longer the case, but stick because unfortunately JD was over charging for a long while and Kubota was making a better product.
/ Another JD vs Kubota question #18
I highly recomend buying what ever makes you happy that has a dealer close by. There are so MANY opinions about what to buy and why. Some say nothing but JD. Others say Kubota because they have fewer problems (no facts of course) others say some lesser known brands because they are a better value...
Good Luck!
/ Another JD vs Kubota question #19
Both of the tractors that you are looking at are great machines. My personal choice would be the Bx, as I have owned a Bx23TLB. It was quite the tractor that could do it all, I was so pleased with that machine and the ability to do any task put in front of it. Oh, It was my understand and I have two Kubota's that the Three point hitch came with tractor, You need to make sure, ask Kubota.com.
DevilDog
/ Another JD vs Kubota question #20
Kubota changed from the rocker pedal to two separate forward / reverse pedals a while back (maybe with the BX24). The rocker mechanism is now under the floor board so you can rest your right foot in the available open floor space between the two - probaly over a foot apart. I find it very natural to step forward to go forward and step back with the heel to go backwards - very intuitive to me.
I would probably agree on the location of the joystick, though I've not tried the JD version. The Kubota joystick has a lock out as well.
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63118)
2017 Cadillac...
2005 Isuzu NQR 4 door box truck with folding gate (A63118)
2005 Isuzu NQR 4...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
UNUSED ATS 4'X300' GRASS PROOF CLOTH (A62131)
UNUSED ATS 4'X300'...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
