What kind of greae
   / What kind of greae #1
Linefuse
John Deere 4310
Just bought a used 4310 ehydro with loader. How often should I grease and what brand of grease?
   / What kind of greae #2
Grease the loader every ten hours and the tractor every twenty-five . I use Mobil 1 grease on everything.
   / What kind of greae #3
You'll want to use a general all-purpose grease with an NLGI grade No.2 rating.
   / What kind of greae #4
Grease the loader every ten hours and the tractor every twenty-five . QUOTE]
Does this mean I have to get up in the middle of the night to grease mine.
Maybe I'll just do it before I go to bed and then again first thing in the morning while the coffee is brewing:D:D:D
   / What kind of greae #5
Me too!!! I have a routine of letting the dog out about 10 PM and greasing the tractor, fel and backhoe then calling the dog back in. :D:D
Seriously though I use marine red grease on most things but I think having a good routine with frequency is more important than the brand.
Steve
   / What kind of greae #6
I've been using Mobil 1 synthetic for 4-5 years now. I needed to change over to a grease (and oil) that wouldn't set up like concrete when it gets down to -40F.
I'm not very concerned with "added protection" for all those +100F days...
AKfish
   / What kind of greae #7
If you do a Google on John Deere Manuals and follow the site you'll get all the information you require for servicing.:D
   / What kind of greae #8
The type of grease used is far less important than the frequency of greasing. There is no 'bad' grease. The important thing is to grease often enough to keep dirt and grit flushed from pivot areas; and to keep zerks from plugging up with contaminated, hardened grease.
UNUSED JCT 72" HYD BRUSH CUTTER (A54757)
UNUSED JCT 72" HYD...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
1987 International S1900 Flat Bed Truck (RUNS)(TITLE) (A50775)
1987 International...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
MISC TIRES (A54757)
MISC TIRES (A54757)
2003 Lincoln LS (A50324)
2003 Lincoln LS...
