FD-
How crucial is the flow requirement?..Now that im confused on the flow required stated in this thread ive seen 30GPM min and 25 GPM min
Sorry for the confusion. Typo error from my part
3500 psi should have been with my 25 gal/min, not 3000 psi:
30 gal/min @ 3000 psi = 52.5 hydraulic hp
25 gal/min @ 3500 psi = 51.0 hydraulic hp
Actually, you probably could run with 25 gal/min at 3000 psi (43.8 hydraulic hp), but then mostly in smaller stuff.
I guess engineers could come with an exact hydraulic power requirements in relation to the total ton of material to mulch per acre. And that could actually be used to measure the efficiency of a rotor technology... But I digress...
Note that, to describe required power, we actually need to talk about a mix of flow and pressure. On carrier spec sheets of a carrier, we always see something like "max flow" and "max pressure". But often, these are unrelated maxima. What you need to know is: what is the pressure when you get that max flow, and what is the possible flow when reaching that max pressure. These will give you a more accurate number for available hydraulic power. And how do you get that? Ask the dealer. Or ask to see flow charts. And if you have a used carrier, you can ask a good hydraulic shop to run flow tests.
Calculation of hydraulic power is :
( gal/min * psi ) ÷ 1714 = hydraulic hp
If you get your flow and pressure from the spec sheets, and the resulting hp is higher than the hp of the engine, that tells you you need to get more info.
If you get a resulting hp that is below the hp of the engine (usually around 85%-90%), then you probably have in front of you the numbers one of the few manufacturer that state the max flow *at a given pressure*.
And lastly, if we say you need "25 gal/min @ 3500 psi", it doesn't mean you have to have 3500 psi. If your machine runs at a 4000 psi, you don't have to install a pressure-reducing valve. We will adjust our machine to your carrier.
FD
