Tractor flips while pulling boat !!!
/ Tractor flips while pulling boat !!! #1
jamestaylor72
Ashtabula, Ohio
John Deere 4120
Here is yet another tractor-flip accident guys !! Thankfully though,, this fella survived !! Be careful out there!
JT
Tractor flips on Monroe resident
By MARK TODD - Staff Writer - mtodd@starbeacon.com
Star Beacon
MONROE TOWNSHIP An 82-year-old Monroe Township man was injured when the tractor he was driving early Sunday afternoon flipped at his State Street home, pinning him underneath the machine, firefighters said.
David Best, 5240 State Road, was taken to Ashtabula County Medical Center by a Conneaut Fire Department ambulance crew. He was conscious and talking with medical personnel at the scene, firefighters said.
Best reportedly was pulling a boat with the tractor when the boat became lodged, causing the tractor to flip into the air, said Conneaut Fire Lt. John Chapin. Best was thrown from the seat, and the tractor fell on top of him, firefighters said.
Best痴 son used another tractor to move the toppled vehicle and free his father, firefighters said.
Because of the nature of the call, Conneaut rescue personnel put a medical helicopter on stand-by status, but the flight was not needed, firefighters said.
Monroe Township Fire Department personnel also were sent to the scene, according to reports. A Conneaut rescue crew was dispatched to State Road at 1:53 p.m.
/ Tractor flips while pulling boat !!! #2
Probably had it connected to the three point hitch, and had it too high.
/ Tractor flips while pulling boat !!! #3
Whenever I read something like this I have to wonder how it was hitched. If anyone knows could you please post that information?
/ Tractor flips while pulling boat !!! #4
Me too... I'd like to see if it was a tractor or lawnmower.
If it was a boat trailer, it must have been on a ball hitch.. makes you wonder how he got it snatched backwards enough to roll.. or did it rear up, and sideroll.
soundguy
/ Tractor flips while pulling boat !!! #5
I have seen far too many hitch balls on the 3 pt instead of on the drawbar.
/ Tractor flips while pulling boat !!! #6
He was probably pulling with the ball on a towbar mounted to the three point and had the hitch too high.
I know that winter's over for most of us but here's a safety tip for winter tractor use. If you park your tractor outside durring freezing weather after you start the machine ALWAYS BACK UP FIRST! If your tires freeze to the ground(frozen mud or water) and you try to go forward, the torque reaction with the drive wheels locked will flip you on your back. Under these kind of conditions, I' ve heard people say they will park with the tractor's nose against a fence, a tree, or a barn wall to make sure they have to back after starting.
Be safe out there now!
/ Tractor flips while pulling boat !!! #7
Thanks for that info Jerry! I thought it was cool doing the winter Wheelie. When you're young you just don't know DANGER!
/ Tractor flips while pulling boat !!! #8
Whats wrong with ball on the 3pt. Thats what make for versatility.
/ Tractor flips while pulling boat !!! #9
Yes it adds versatility, but if you know anything about physics, if you don't keep the ball as low as possible, level or below the rear axle you are looking for disaster in a hard pull. The other thing is that if the tractor does start to bring the frontend off the ground the 3pt will raise whether you lift it or not.
/ Tractor flips while pulling boat !!! #10
The price of that versatility is a tendency to overturn if whatever you are towing hangs up. Or if you use it for a hard pull.
/ Tractor flips while pulling boat !!! #11
Thast's why it's mandatory to use a drawbar lock, sway bars, and stays, if you run a ball on a 3pt drawbar.. keeps it from rotating, keeps it centered and not swinging, and keeps it down in case the nose of the tractor comes up.. or the front of the trailer goes gown.
most people ignore the stays and therin lies the problem..
soundguy
/ Tractor flips while pulling boat !!! #12
How about those log handlers on the three point . The chain attaches high , the 3 point lifts the log a bit and you can drag it away. Seems like with all the discussion about attaching too high this method would not be too safe. I just dragged out 10 logs like this.
/ Tractor flips while pulling boat !!! #13
May be this is why i always have my foot right at the clutch when i a on it. I fear rolling sideways, since all my property is on hills but never once have i not been able to push that clutch in fast enough to bring the front end back down while pulling way to many trees up out of the woods. Their must be something to be said about going through the weekend at .5 mph.
/ Tractor flips while pulling boat !!! #14
We have used 3pt hitch mounted trailer balls for years. Not only the small ones but we use them to move gooseneck hitch cattle trailers. We load about 20000lbs of cows in the gooseneck trailers and pull them out of the pastures, up hills, across slopes with no problems.
Secret is............Use Enough Tractor
So many times people get hurt because they go beyond the capabilities of their machines. I see this with the smaller farm tractors and with small dozers and loaders. Whether you have it hooked to the drawbar or not, if you exceed the capacity of the machine you are in danger.
/ Tractor flips while pulling boat !!! #15
If you are going to pull a load with a tractor, pull it in reverse. Use chains, chokers, draw knots, whatever you need to do to get the nose of the load off the ground to make it moveable. It is almost impossible to get a tractor to nose over forward since the drive is in the rear. Physics is on your side when you are pulling in reverse. Be safe out there.
/ Tractor flips while pulling boat !!! #16
Tractors have drawbars in the rear.. not front!
while a front ball on a bumper is usefull for osing in small loads like tendering boat trailers.. or other small utility trailers.. pulling from the rear is the generally accepted method.. besides.. if you have chevron ag tread.. it -IS- directional..
soundguy
/ Tractor flips while pulling boat !!! #17
Hmmmm.....I've read this enough to take note of this issue. I use my box blade for ballast and just recently mounted a receiver hitch on the back of my box blade for convenience in towing stuff. I put a 2" ball with about a 6" drop on. It's located pretty far back from the draw bar....so I suppose I have lots of leverage on it. So far I have used it to pull some heavy logs and to move trailers around...without problems. But.....this post has me wondering if this is a good practice....have not given it much thought. :confused: I do not have stays...but keep my check chains pretty tight.
The part above...about the 3 point raising whether you lift of not....gives me concern.
/ Tractor flips while pulling boat !!! #18
A box blade on back does help you... it provides a stall point where it maxes out in height, and then is rigid, where the wheels will have to break traction.. ( or theBB or 3rd link has to fold.. etc.. )
soundguy
/ Tractor flips while pulling boat !!! #19
soundguy
OK....Thanks....sorta what I thought......but wouldn't a boat (like in OP's post) help too? :confused: Sometimes a pic is worth a thousand words.
One thing I have concerns about with that hitch on the back of my box blade (aside from safety).....is that I can sure put allot of pressure on my 3 point if not pulling straight....but it sure is handy.
/ Tractor flips while pulling boat !!! #20
In a pulling application.. IE.. a rolling load like a trailer.. if your 3pt will pick it up.. and you have check chains to keep the arms out of the tires.. you should be able to 'tend' trailers with no problem.
IMHO. I'd rather move a trailer with a ball on a BB than on a 3pt drawbar.. the BB sets back from the tractor and thus makes a lower angle stall point if the tractor nose did try to climb.
soundguy
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2022 Deere 17G (A64126)
2022 Deere 17G...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
451 New Holland Sickle Bar Mower (A66408)
451 New Holland...
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
(16) Kinze 60 Cell Bean Plates (A65640)
(16) Kinze 60 Cell...
