Ford 850 Dependant PTO
/ Ford 850 Dependant PTO #1
bobcat753
HI all,
Was looking at one of these tractors to run my JD 24T small square hay baler. Is it even possible to run this type of baler with a dependant pto? According to the manual I need a 540 or 1000 rpm pto.
Thanks,
Ryan
/ Ford 850 Dependant PTO #2
HI all,
dependant pto?
Thanks,
Ryan
Do you mean Transmission driven pto? if so then the pto should get a shock load operating a baler and moving the tractor both at the same time. live or independent pto should allow you to bring the implement up to speed and then move the tractor. I don't have particular experience with 850, but I know a friend that ran square baler with equally transmission driven 8N, but he said it is a rough ride and his 8n was squealing pretty bad.
JC,
Ryan,
Out of curiosity I searchd JD 24T and found below video. It showed the mentioned bailer with an engine that ran the baler. Is yours PTO driven or has it's own engine?
http://www.youtube.com/watch?v=q3RnYdDAdFg
JC,
Ryan,
YouTube - Baling Hay with the John Deere 24T Baler
JC,
I've seen that video before mine is a 540 PTO driven baler and looks almost identical to that one minus the engine. Before live or independant pto drives they had dependant ones. Basically I believe the how it works is the PTO is directly tied to the rpms of the tractor and drivetrain. So when you slow down so does the pto.
I found a post on this site bailing hay without live pto that sounds interesting. Plan on looking at a few other tractors, and from what I've read a live pto is almost a necessity.
12ton Hydraulic Bottle Jack (A64557)
12ton Hydraulic...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2010 International 4300V TYMCO 500x Regenerative Air Sweeper Truck (A66736)
2010 International...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2023 Dodge Durango AWD SUV (A66738)
2023 Dodge Durango...
2016 John Deere 250G LC Hydraulic Excavator (A66734)
2016 John Deere...
