Ford 850 Dependant PTO
/ Ford 850 Dependant PTO #1
bobcat753
HI all,
Was looking at one of these tractors to run my JD 24T small square hay baler. Is it even possible to run this type of baler with a dependant pto? According to the manual I need a 540 or 1000 rpm pto.
Thanks,
Ryan
/ Ford 850 Dependant PTO #2
HI all,
dependant pto?
Thanks,
Ryan
Do you mean Transmission driven pto? if so then the pto should get a shock load operating a baler and moving the tractor both at the same time. live or independent pto should allow you to bring the implement up to speed and then move the tractor. I don't have particular experience with 850, but I know a friend that ran square baler with equally transmission driven 8N, but he said it is a rough ride and his 8n was squealing pretty bad.
JC,
Ryan,
Out of curiosity I searchd JD 24T and found below video. It showed the mentioned bailer with an engine that ran the baler. Is yours PTO driven or has it's own engine?
http://www.youtube.com/watch?v=q3RnYdDAdFg
JC,
Ryan,
YouTube - Baling Hay with the John Deere 24T Baler
JC,
I've seen that video before mine is a 540 PTO driven baler and looks almost identical to that one minus the engine. Before live or independant pto drives they had dependant ones. Basically I believe the how it works is the PTO is directly tied to the rpms of the tractor and drivetrain. So when you slow down so does the pto.
I found a post on this site bailing hay without live pto that sounds interesting. Plan on looking at a few other tractors, and from what I've read a live pto is almost a necessity.
2003 Toyota Sequoia SUV (A66738)
2003 Toyota...
2018 CHEVROLET IMPALA (A66091)
2018 CHEVROLET...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
2009 CHEVROLET IMPALA CAR (A66091)
2009 CHEVROLET...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
