JD4200 Third SCV Kit........(again)...!!!!
/ JD4200 Third SCV Kit........(again)...!!!! #1
Scotty370
Buffalo, New York
318 John Deere, 4200 John Deere, 1947 John Deere "M"
Sorry to beat you guys up with a well covered topic, but I've got the tractor outside, $300-, worth of nuts, bolts, cable, tubes, QD's, handle, tools at the ready.......oowwww, this could be ugly! My only question is this- The Control Handle that will be mounted to right fender, is a 'friction lock' type, not self- centering, as I envisioned. It doesn't even have a 'notch-plate' to keep it in Neutral! What happens when it gets pushed fore or aft, without an outlet cylinder conected to the rear ports? A lot of 'hydro-growl', I would suspect! Any one done this on a 4200, with the back-hoe mounting plates installed? ~Scotty
/ JD4200 Third SCV Kit........(again)...!!!! #2
Scotty:
I put the 3rd, 4th & 5th SCV kits and Power Beyond kit on my 4200 myself. So far I've just noticed the hydro-growl you mentioned. I need to get some hydraulically powered toys to go with the kits.
I'm going to make a suggestion to hopefully make your life easier. If you haven't got the PB kit, get it and install it at the same time as you do the 3rd SCV since you'll have the seat and right wheel & fender removed. I had to notch my fender to adjust the 3rd SCV clevis. Also the instructions call for adjusting the 3rd SCV clevis after the right wheel is on...yeah right, they goofed on that one.
Unfortunately with those kits being cable operated they won't return to neutral, so I think one will need to mark where neutral is after determining that location.
If you want a 4th & 5th SCV kit, I may know of one left in the country, and you will need the PB to make it work.
/ JD4200 Third SCV Kit........(again)...!!!! #3
The Valve spool itself is what is supposed to center the handle-that's where the springs are. BUT-as MJ said, with the friction of the cable it does not work so well...
Well, it’s DONE! If you don’t count the tractor on jack-stands, rear tire removed, no right rear fender, no cover plates, no seat,……Sounds done to me! But seriously, I got the control body out, retrofitted with linkage bracket, bell crank etc. etc. etc. Got it all mounted back on top of the transmission, and all the ‘blessed’ lines reconnected! Kind of a funny start. After stripping the tractor seat, tire, fender, etc., the first thing it says is “Loosen the four hydro lines from the QD’s under your right foot plate.” I guess, for tube movement. Well with the FEL on, I couldn’t get in there to loosen them! What to do? Like any good (?) mechanic, skip to the next step!!! Actually I think it worked out better, ’cause it held all the lines right in place! The kit gave me more hydro-bushings than I needed! Do they put extra parts in just so you ’quadruple’ read the instructions? Good to have the extras though, one of the “O” rings had a big nick out of it, that would have me doing the whole job over had I not seen it! I had PB previously installed, Mjncad, so that saved me the rear bracket work. Dare I ask where the 4th and 5th valves go? Thanks, guys! ~Scotty
/ JD4200 Third SCV Kit........(again)...!!!! #5
The 4th & 5th spools are in a single valve body just above left axle. Follow the control cable in the picture. The QD's are to the left of the PB and 3rd SCV QD's. Notice it is a snakepit with all the stuff installed.
/ JD4200 Third SCV Kit........(again)...!!!! #6
Does the 4200 use different cables then whats on the 3x20 Cab machines? I find all my cable controlled SCV's (the 2 loader and 1 Rear) are smooth as silk...they return to neutral perfectly, etc...
/ JD4200 Third SCV Kit........(again)...!!!! #7
No clue Dave, would have to research it on JDParts...But the know the control on my friends 4400 is very stiff.
I'll have a better 'handle' (Bad pun!) on the handle return issue when I button things up this weekend. The 'spool' springs in the valve body do seem pretty spunky though, and the friction block at the lever could probably be 'backed-off' a bit. Darn MJN.. that looks like an industrial hydro-source disguised as a tractor!!!~S
/ JD4200 Third SCV Kit........(again)...!!!! #9
Yeah it does, which is why I want to eventually do some rework with hard lines to get rid of the space robbing hoses, because the 4th & 5th SCV's are a kludge powered by the PB kit. Since the rockshaft control valve doesn't have a PB port, I can't pipe it up simple as it should have been done by Deere.
Let us know how adjusting the lever friction block works out.
/ JD4200 Third SCV Kit........(again)...!!!! #10
Scotty,
Let me know how you make out on adjusting the friction on the control handle. I have the same issue with the "hydraulic growl" if I don't center the handle.
mjncad,
Have you run into any problems hooking up to the quick connects next to the power beyond? I have a 4400 and it seems like the power beyond connectors are always in the way. I also noticed that I have a hydraulic fluid leak behind the fender and I will have to take the wheel and fender off to get at it, (hopefully a loose fitting) so I am wondering if I could use hoses instead of the hard lines and then run them up to a mounting bracket that I would attach to the fender or ROPS. Anybody have any suggestions on that, like where I might be able to obtain a bracket that I could u-bolt to the ROPS or bolt to the fender and then use Q/C's other than the expensive JD ones.
I purchased a hydraulic top link from C&C and I had to change the Q/C's they gave me to some that I had to purchase at the JD dealer.
Any ideas or help would be greatly appreciated.
Thanks in advance,
Eldon
/ JD4200 Third SCV Kit........(again)...!!!! #11
I got some 3/16" plate from the metal surplus place in town. Used some step bits from Harbor Freight and a drill press and made my own mounting plate. Oh, and I used a sawzall to cut the plate to size. Made my own U-bracket since my ROPS is rectangular tube. This was some metal strapping with threaded rod welded on. Shortly I will be posting a thread showing my project.
Eldon- Do you have the factory JD bracket that holds the PB lines along with the 3rd QD's? I got one with my PB Kit, Now I've got another!
Eric- My extra bracket won't help you, 'cause it's JD specific. But sounds like you've got you mounting on the run! Just a note, I've gone to NAPA and gotten spring bracket bolts when I've had to attach to square/rect stock. Just u-bolts, w/ square bottoms! ~S
/ JD4200 Third SCV Kit........(again)...!!!! #13
I knew someone had to make them. I will keep that in mind next time I need a square U-bracket.
/ JD4200 Third SCV Kit........(again)...!!!! #14
mjncad,
Eldon
All of the QD's back there are too close in my opinion, and yes I do have trouble connecting items because of the limited space. I have the same issue with the loader QD's too.
Since I helped the economy by buying lots of crowfoot wrenches to install my kits, I managed to torque all my lines to spec and knock on wood I haven't had a leak. If your leak is at a fitting, I'd try tightening it down a bit. I don't see how changing to hoses will help the leak issue, and all it will do is make a cramped space even tighter. If I understand what your planning, it could make the seat rub against the hoses too.
Hopefully you didn't cross-thread a fitting in an expensive valve body.
/ JD4200 Third SCV Kit........(again)...!!!! #15
mjncad,
The power beyond and the third SCV were installed as part of my backhoe package so I'm hoping that they didn't cross thread any fittings. The reason I was going to use hoses was to move the disconnects away from the power beyond fitting and hopefully put an electrically controlled splitter so that I can add a tilt cylinder to my hydraulic top link. Thanks for starting the post and adding the pictures because it was exactly the set up on my tractor.
Eric, I'll try my hand at metal fabrication and see if I can come up with something.
You guys gave me some great ideas and helpful information. I'll see what I can do.
Thanks again,
Eldon
/ JD4200 Third SCV Kit........(again)...!!!! #16
mjncad,
The power beyond and the third SCV were installed as part of my backhoe package so I'm hoping that they didn't cross thread any fittings. The reason I was going to use hoses was to move the disconnects away from the power beyond fitting and hopefully put an electrically controlled splitter so that I can add a tilt cylinder to my hydraulic top link. Thanks again,
Eldon
I hate it when I wreck something I'm installing; but I get real upset when I pay good money for someone who claims to be an expert wrecks something. Hopefully all you need to do is snug the fitting down and you'll be good to go leak wise.
If you fab up a new bracket for an electrically controlled diverter, I hope you post pix as I know I would like to see what you come up with.
/ JD4200 Third SCV Kit........(again)...!!!! #17
....so I am wondering if I could use hoses instead of the hard lines and then run them up to a mounting bracket that I would attach to the fender or ROPS. Anybody have any suggestions on that, like where I might be able to obtain a bracket that I could u-bolt to the ROPS or bolt to the fender and then use Q/C's other than the expensive JD ones.
I used hoses instead of the JD hardlines on my previous JDs, and I plan to
do that with my 4300. I have never used those friction-type valves and I
plan to use a good Prince monoblock instead. I never buy JD QDs, BTW.
Since the 4300 hydraulics are new to me, I will be watching for any pix
of 4200/4300/4400 hydraulics!
OK, MJN, I'll start with your....".....I hate it when I wreck something I'm installing..."!!! Man! Have you been watching me? You were 'spot-on' about that 'clevis' adjustment. I set the cable bracket in the jam-nut, U-slot, and the clevis I centered for adjustment in both directions. Re-mounted the fender, and did the cable-routing, hole drilling, routine. I found that the handle didn't throw the spool far enough, so I had to take the fender back off, and I had two choices, either lenghten the cable connection at the clevis, or, loosen the jam-nuts, and move it forward, (I needed about1/4") and re-tighten! Opted for that! Well, tighten I did! Broke the cable collar, right at the bracket mount! Well it was a 'clean break' so as a stop-gap measure, I threaded the rear jam nut up over the break, and got the two pieces together inside the rear jam nut! I extended the clevis, put it all back together, an everythings good. Well until I order a new cable. At least I'm only looking at tire and fender removal to get it replaced, not the whole ordeal! Just gotta put the seat on, but fired it up, to no leaks, of course the 3SCV line are probably still empty! Oh well, tommorrow's another day. Just an update on the friction lock. By backing off the friction lock bolt, (under the fender-mounted control lever), it will return to center!! Why can't they just put the linkage adjustment up top? ~Scotty
/ JD4200 Third SCV Kit........(again)...!!!! #20
I'm not Big Brother, so I wasn't watching. :rolleyes:
Yeah, isn't that fun trying to get to that 3rd SCV clevis? Wasn't it fun trying to get the split grommet around the cable installed into the hole you drilled in the fender? I had three of those to do and I swear I probably lost a couple pounds of flab burning calories getting that done.
I've added another round-to-it to my collection...to investigate whether I can fabricate a mechanical linkage to get the full range of motion from the fender levers while still getting return to center capability similar to the loader lever. Don't hold your breath waiting on that from me.
As to your last statement Scotty...JTPYO = Just To Pi$$ You Off!
2021 CATERPILLAR 303.5E2CR EXCAVATOR (A62129)
2021 CATERPILLAR...
NexTier Frac Manifold T/A Trailer (A60352)
NexTier Frac...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
500BBL WHEELED...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
2017 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A62129)
2017 CATERPILLAR...
