Can they be ordered now (quick attach)?
/ Can they be ordered now (quick attach)? #1
Rowdius
Nugent, Texas
Kioti CK35 With KL130 Loader
Back in Janurary WallaceTractor told us all about the new quick attach for the CK series, but said that at that time it was only on the new loaders, that they were unable to order just the quick attach.
I'm wondering if this still holds true, or is it possible to just order the quick attach for my 2008 CK35? And how much it would run...
/ Can they be ordered now (quick attach)? #2
I'm pretty sure you can get a QA adapter for any of the CK's. Don't think it's exactly the same as the new factory QA's, but it will serve the same function. QA bolt-on adapter mechanism, and then you can buy a weld-on adapter to convert your bucket.
/ Can they be ordered now (quick attach)? #3
We carry QA Adapters for the CK Series Loaders. Let us know if you need help.
I knew ATI had them, but I was curious to see if Kioti's would be any cheaper. I think the ATI starts out for $750 for the loader side of the quick attach, and the weldable plates for the attachment side can be found for $150-$250.
I'm still a bit away from being able to afford it I'm thinking, but am looking for a ballpark figure to know what to save for.
/ Can they be ordered now (quick attach)? #6
I don't want to hijack the thread, but besides the QA loader, what other QA implements are available and where do you go to get them? The Kioti dealer?
/ Can they be ordered now (quick attach)? #7
Some Kioti dealers carry QA attachments but many are sourced from attachment manufacturers. Grapple, tree boom, 4n1 bucket, forks are examples of QA attachments. Some are practical for smaller tractors while others are too heavy to be of practical use except with bigger loaders. For example, it is not practical to use a QA attachment weighing much more than 400lbs on a KL120 or KL130 loader as you will simply not have much net lift capacity remaining. Check out the attachments forum and you will see lots of discussions of grapples, 4n1 buckets and other QA attachments.
2016 Ford F-150 Pickup Truck, VIN # 1FTMF1C85GKE26496 (A61165)
2016 Ford F-150...
2005 SHOP MADE MANIFOLD TRAILER (A60736)
2005 SHOP MADE...
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
1995 Kawasaki Bayou 300 4x2 ATV (A60352)
1995 Kawasaki...
