Running on one Cylinder
/ Running on one Cylinder #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I had a minor problem with the PT422 and Robin engine yesterday. I started it up and it ran rough. I pulled one plug wire and there was no change in engine running. I pulled the other and the engine stopped. It would not run at the normal idle setting. I pulled the plug and it was wet. I checked the spark and it was OK. I replaced the plug with a used one in good condition. Same problem. I looked at the air filter and the foam prefilter was seriously dirty. I cleaned that. The filter looked good. I spun the engine over with the plug removed and replaced the plug again. I then ran it for about five minutes and the plug starting firing again and it ran fine. I then mowed for about 30 minutes and everything was OK. I guess I need to check the prefilter more often.
I just wonder if my diagnostics are correct. Any suggestions on this. I used to run platinum plugs and should probably go back to them.
/ Running on one Cylinder #4
Yeah, check that air filter often! I know a guy who owns a large lawn service. He said they used to change the oil in their mowers once a week, but over time and experimenting they figured out that they could extend the service intervals longer than recomended without doing any harm to the motors as long as they cleaned the air filter every day. Of course this is in some of the toughest conditions like hot dry and dusty. When it was real dusty he even went as far as to give the crews extra filters to change during the day.
Good info, thanks. I need to get several of the foam prefilters and clean a bunch at one time. Then swap out often.
/ Running on one Cylinder #6
Bob.
I don't think the filter had anything to do with the one cylinder not firing. If for some reason the one cylinder does not fire, and gets wet from fuel especially with full choke setting, it will stay wet and and bleed the spark to ground. If that cylinder had spark, the best thing to do is to dry the plug and try again with out choke. They make an in-line light that will flash if the coil is putting out voltage. Take the plug out and connect wire and crank over and see if the plug fires. You can definitely tell when a cylinder is not firing.
Bob.
You have some good points. I checked for spark with a screwdriver and of course tried a torch to the old plug, and then new plug. I did start with full choke and did not try starting with no choke (probably the problem). Will the light tell when the plug is bridged by gasoline or whatever? I have a spark gap device like this and did not use it here. I will look for a lite today when I get platinum plugs. I was kinda surprised when I had to let it run for several minutes before it finally fired. It might be a weak coil (if that is possible).
/ Running on one Cylinder #8
If you have a badly clogged air filter, the engine will pull a high vacuum, which will tend to suck gas and/or oil into the cylinder. The oil either gets past the rings or the valve seals. The gas gets sucked out of the carb. If there is insufficient air flow due to the clogged filter, the gas won't atomize properly.
If any of it gets deposited on the plug in a liquid form, the plug won't fire, so it could have been the clogged filter.
Once you changed the plug, the cylinder probably wouldn't fire because it was wet with gas. The fact that it took five minutes to dry out and fire is very unusual. Possibly, there is something wrong with that cylinder.
I assume the Robin has an automatic compression release like the Kohler. Those things prevent you from accurately testing the compression with a simple compression tester. A leak-down tester being required to accurately test the compression.
However, you can still do a relative test with a simple compression tester. If one cylinder is markedly lower than the other, it will be bad. Test at WOT with both plugs pulled.
There is such a thing as a weak spark. It usually isn't the coil that causes it, but it isn't out of the question. Bad spark plug wires are the most likely cause.
/ Running on one Cylinder #9
Bob.
The ignition light only tells you that you have high voltage going to the plug. If the light is flashing and the engine is not running right, it means that the voltage is being sent to ground to ground through the plug, Bad plug, carbon-ed up or wet. If the plug will fire outside the cylinder, you should be good to go. I used to make ignition testers out on those NE2 bulbs, just spread the leads and wrap around the spark plug cable. I also used the old transistor radios to time the engines. You could rock the flywheel back and forth and hear the static when points opened and the coil would dump that high voltage.
Snow, J_J, The engine is running a starting fine. I did put new platinum plugs in it today. It is my intent to just use it and not do any more test. The compression test would be easy and I will try it soon, I hope.
I ran a compression test today. 170 pounds in both cylinders, so that seems to be OK. I have not had any problems lately. The plugs (which are new now, maybe 2 hours) look real good. I will keep on PTing.
/ Running on one Cylinder #12
Excellent.
/ Running on one Cylinder #13
I just replaced the original Champions in my Kohler, after 500 hours. NAPA didn't have NGKs that would fit it in stock, so I went with Bosch.
We'll see how they do over time -- used to run nothing else in VWs. The difference in starting now is noticeable... but time will tell.
/ Running on one Cylinder #14
just a word of caution about test firing plugs outside of engine, my neighbor burned down a new simplicity riding mower doing that, was checking spark in one cylinder and motor started running which created a blowtorch effect on the opened cylinder before he could get it shut down/water hose to put out fire, but I am sure all pt owners have more common sense:cool::D
Oh, I forgot to thank everyone for their help. Thanks to everyone.
/ Running on one Cylinder #16
You bet!
That car going up in flames, due to cranking with the plugs out and the gas line disconnected never happened to anyone here. Sure, that's the ticket. :eek:
/ Running on one Cylinder #18
The day I had to cut off the roll over assembly on my PT, I had this Stihl 760 cut off saw going with a metal cutting blade,and sparks going all over, and I felt my leg burning, I looked down and my leg was on fire, and my pants had caught fire and burned a large hole in my pants, and, put a good burn on me. How stupid was I? I didn't realize the pants were a mixture of cotton and whatever that other stuff is at a 50/50 mix. Anyway, I have a leather apron now, if I can remember to use it.
/ Running on one Cylinder #19
A few years ago my neighbor was welding on a car in his basement garage. There's a new house there now.
/ Running on one Cylinder #20
Yeah. I lit myself up in a welding class once.... had my shirt tucked in and burned my belly button when sparks landed behind my belt buckle and started my shirt of fire. :rolleyes:
But never a vehicle!!! :D
(yet :p )
