Floor finish in the tractor garage
   / Floor finish in the tractor garage #1
JonKioti
Newfoundland, Canada
CK-20S HST
Hi all,
I've taken the time to build a semi-heated space for my tractor; I have a power trowel finished slab on grade. I'm hoping (probably in vain) for a clean space which is easy to clean up dirt, debris, etc.
Does anyone have a suggestion as to what to use? I'm looking toward an epoxy coating, but maybe someone has an idea of something else.
Thanks!
Jon
   / Floor finish in the tractor garage #2
I would just use a good sealer
   / Floor finish in the tractor garage #3
ditto
becareful how smooth you make it when trowelling, because when you add sealer or epoxy it maybe TOO smooth, and you might fall on your a-- when its wet. don't askhow I know.
(In jest) - we're not allowed to hunt the seals anymore, so it should be easy to find a good sealer. :)
A good concrete sealer in one option, for sure. It does make for a dark colour floor, but has less steps than the epoxy.
Joe, thanks for the tip. I will test with non-critical area first (the job will be done in sections).
Jon
   / Floor finish in the tractor garage #6
when we pored our basement we flooded it with an acrylic based sealer - did not change the color of the concrete, but water beads up plenty well.
   / Floor finish in the tractor garage #7
When talking to concrete finishers I have always asked for a broom finish, rough enough so I don't slip when it is wet, smooth enough so I don't tear my clothes when I crawl under a car. All the finishers I have hired have been able to do this.
I just leave it "as is". Dust sweeps up well, oil spills go away with absorbent, followed by clean absorbent and some paint thinner.
   / Floor finish in the tractor garage #8
I think the concrete has already been poured:rolleyes:
   / Floor finish in the tractor garage #9
"build a semi-heated space for my tractor"
What does "semi-heated" mean?
   / Floor finish in the tractor garage #10
Maybe a wood stove. Heated only semi-the-time when you're there to throw a few logs in. :)
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
PALLET OF MISC CERAMIC TILE (A58374)
PALLET OF MISC...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
Entyre Chip Spreader (A57453)
Entyre Chip...
1997 Caterpillar 950F Articulated Wheel Loader (A55973)
1997 Caterpillar...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
