DIY Home built compact tractor
/ DIY Home built compact tractor #281
What ever makes your leg sit comfortably. You will quickly adjust to the view, but if not sitting tension free, will cramp up quick and have no fun on the tractor.
jb
/ DIY Home built compact tractor #282
jb
I will 2nd that, I have 2 tractors that I use around the house, one is an 1983 international 244, 20 hp 3cyl diesel (built by mitsibishi) 2 hours on it and your worn out, the other is a 1942 farmall H, I can use it all day and not be tired. it all boils down to sitting position, the 244 feels cramped, the H doesn't.
my 2 cents, great build by the way!
I started on the seat platform. Cutting and tacking pieces, finish welded.
Here the seat is temp clamped on and the battery box and hyd tank kind of sitting in there.
/ DIY Home built compact tractor #284
It looks like the seat is slightly offset to the righthand side. If so, I'm just a bit curious why you did it that way, instead of centering it?? I'm sure you have a good reason.
/ DIY Home built compact tractor #285
Battery box is to the left, easier to get out is my guess. :)
Optical illusion, Its centered, however the steering collem is off to the left at the base.
At this point I think the battery is going to slide out the front.
/ DIY Home built compact tractor #287
Great thread, I also joined because of this. I've been kicking around the idea of building a compact/garden tractor, not quite as ambitious as this but 2wd and around 10 hp.
Great tractor! Its looks like it'll be a real workhorse! You really did inspire me, I went ahead and built a small tractor, just on a smaller scale. I have a lot of walk-through gates, so I had to keep mine under 32" wide. Using quick disconnect hydraulics to attach implements, and hydraulic motors to run things like post hole diggers and such.
Glad I could help!;)
What kind of set up have you got on the front steering gear?
Tim
/ DIY Home built compact tractor #290
I'd like to see more of your tractor.
/ DIY Home built compact tractor #292
Very cool little machine! Is that a self leveling bucket?
/ DIY Home built compact tractor #293
You can just run the cv joint at the gearbox and tilt the diff up so the u joint runs straight/flat. That is what you need to/should do at both ends to not have vibration. Too bad you already welded the ends on the front because when you tilt the diff the castor will also change. It may not matter much at low speed but could be fun down the road. I wouldn't mess with putting a cv joint at the diff or worry about the front angle at the speeds you are planing (u joints are cheap and I have run them alot steeper than that). What size tires are planning on the front (front and rear need to be the same if you are using the same gear ratio in both)? Will they hit the frame at full lock? I think you are gon'na be pretty high geared for a tractor (should have crawl ratio in the 200s) but if you don't plan on alot of ground engagement it isn't a big deal. Otherwise it looks pretty kool. Who needs body parts?
Go to CALMINI Products Inc. - Suzuki, Nissan, Isuzu Suspension Systems and Lift Kits. They stock all kinds of off road parts for the samarai, and u can get a set of 5.83:1 Gears for the sammy axles... i think they have selectable lockers too, which would be very handy if you plan on using this for cutting grass, too.
/ DIY Home built compact tractor #294
While I think low gears are cool, you have to remember it won't be as strong. This is because with a lower gear (numerically higher) the pinion gear is smaller with less teeth.
/ DIY Home built compact tractor #296
Tim
The front steering gear is a bit of a sore point, I'm not happy with it yet. It came about when my buddy and I were working late one night, and had a bit of a bet on how fast we could get it working. We made a 3:1 box out of off the shelf gears and some 1.5 x 4 bar stock, put a U-joint on that to a shaft and lever arm, then another lever giving it another 1.5:1 advantage. It does work, but not as easily as I'd like. Its pretty tiring after a few hours.
The next plan is picking up a car steering box (I'm going to try a vega box like the hot rodders use) and give it a shot. That has a 15:1 ratio, much better than the 4.5:1 effective ratio I have now.
Oh, and the bet results? He said one hour, I said two, took about four. We both lost.
/ DIY Home built compact tractor #297
how heavey is that bb and does it have scarifiers?
Its around 80 lbs with the scarifiers. I put three of those on there for now, spaced about 10" apart on a 34" bb width. I didn't really know how deep they should be, so I drilled a row of holes 1" apart so I can set the length with pins. I've been running them about 2-4" below the blade level depending on the traction, is that a good setting?
/ DIY Home built compact tractor #298
Thanks! I would call it a self leveling bucket, I set the linkage to give a little bit of an arc, so it does tip upward a few degrees through the travel. I really took a guess about that, but at least it doesn't dump the load on your head when its up all the way!
/ DIY Home built compact tractor #299
I'll attach a few more pics, have some video but I haven't figured out how to attach that yet...
/ DIY Home built compact tractor #300
I noticed your fel cylinders are close to vertical compared to the typical fel being near horizontal. To me it seems your design would have more leverage and have more lifting power being near vertical. My guess is the reason a "typical" fel uses horizontal cylinders is for more support and strength when pushing?
Case IH Magnum 380 (A64126)
Case IH Magnum 380...
2001 MACK CH613 T/A DAY CAB ROAD TRACTOR (A64276)
2001 MACK CH613...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2017 Mercury SeaPro 115HP Outboard Boat Motor (A61574)
2017 Mercury...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65583)
IMPORTANT PLEASE...
