noobie asking for advice
/ noobie asking for advice #21
That L39 looks sweet Do you think I could pick up and hook the bucket on with 1 hand? :) Kubota Tractor Corporation - TLB Series - L39 Loader/Landscaper Tractors
Sure that would be doable. I keep a length of pipe on the machine to help move the levers on the q/a. The pins need to be greased regularly.
Saturday at my friends place, running his older L48, I coulda used three hands. He has the aux. hyd. valve mounted on the fender, the loader valve is forward and no hands left for steering. I did not like his setup at all. Way too clumsy and awkward for me. He has a grapple on his digging bucket and that really made me appreciate having a dedicated grapple setup.
Well I've had a while to surf and think about things and it looks like my wishes and my wallet will have to meet somewhere higher than I had hoped.
I'm looking strongly at things ranging from a $10K or less used Bobcat to a used Kubota L39 for about $25K. Got to keep it around 6K LB or less.
I realize the BH on a Kubota could be worth $5K or more.
Questions for here about the Kubota's:
Are there any worthy competitors in the Kubota L35/L39 weight range ?
What about the B26?
Is the main difference between the L35 and the L39 the BH and 4 hp?
Does the L35 use about the same BH as the L26/L21?
Are there major "repair hours" points? Is 1,000 hours to many generally? 2,000?
Do you generally have to replace some thing-a-ma-jig after X hours? For instance plan on replacing tracks after 2,000 hours on an MTL.
Again thanks people for all the input.
/ noobie asking for advice #23
Hmm, I thought the L35 included the backhoe. Difference in HP and probably BH digging depth/reach.
Price is another who knows right now. Was shopping for a Kubota MX5100 or Kioti tractor for the farm. Price sent me back to Kubota. On the way to double check, one last look see, on the Kubota and saw a new JD 5305 w/522 loader on a JD dealers lot. Stopped by to look and gawk, salesman convinced me that I wanted to own a new JD. It's being delivered today for less than I could get the Kioti or Kubota.
Have you checked places like Construction Equipment at Machinery Trader: Caterpillar, Komatsu, Case, John Deere, Volvo
Hours are another variable, no tried and true hour meter numbers (that I can think of)for expensive maintenance. Rubber tracks don't either though......usually the operator(s) and lack of regular maintenance help determine the breaking points.
Yes L35 is supposed to include BH, but the BH on the L39 "looks" more substantial than that on the L35, B21, B23. But I've not stumbled acroos a part number reference guide.
Yes, that and prices at IronPlanet and Craigslist.
I did see someone post in the Kubota forum that one should expect to rebuild a diesel after 2,000 hours, which seemed kind of soon to me. However I've seen a lot of posts about rubber tread life being short.
With my diesel VW we worry about timing belt replacement at 100K.
Once again, thanks for the info. If only I could exceed the 10,000 pound load limit.
/ noobie asking for advice #25
To answer your question about add on tracks, a friend bought a set for his Cat skid steer and they were junk after 2 years. 2 other friends have ASV units and love them. I agree with hiring out dozer work instead of trashing a multi purpose machine.
/ noobie asking for advice #26
I will not add anything to the equipment choice debate but I would like to suggest that you carefully consider what these guys say. Eddie in particular has a LOT of experience doing exactly what you say you want to do. I own some equipment (mulchers) and have worked in the woods all of my life and I can tell you that no matter what you end up with you will run out of power and capability by lunch on your first day. Get the biggest and most powerful whatever you buy! A big ole TLB is hard to beat for versatility and capability but skid steers are hard to beat for speed and agility. Get the newest and most up to date machine you can find, since you will be working on your own land breakdowns will not be as costly as it would be for a contractor relying on his machine to feed the kids but frequent breakdowns are still frustrating and expensive. Consider contracting or renting the big jobs and then getting a smaller machine for maintanance after the big work is done. This was my very long winded way of saying listen to guys who have already done what you are wanting to do, it will save you trouble.
You know what they say...a wise man learns from his mistakes, but a very wise man learns from others mistakes.
/ noobie asking for advice #27
What about the B26?
The Deere 110 is every bit as capable as either the L35 or L39 - IMO. Nearly identical specs to the L48; minor details different. Quite a few good used ones available in the $25K range, too.
I rented a B21 or B24 (not sure exactly) about 10 years ago to redo my lawn top to bottom and all the final work on a 1 acre horse pasture - rototilling, leveling, seeding, fert application, packing.
Very capable machine but I think you will find it to be pretty small for many of your purposes. The B26 is about 7.5' high and 4.5' wide with the hoe and weighs in around 4K. That fits your trailer requirements.. but those 300 acres will make it (and many machines) real small - real fast.
Unless a machine has been used pretty hard and "put up wet" with little or no maintainance - the 2,000 hr overhaul need is not a reasonable concern. Kubota makes a super reliable engine for many applications and they will normally run - reliably - 3 times that figure (or more).
The hoe on the B series is about a foot and a half less digging depth than the L35-39. Not the same hoe.
With hours and use; the wear points on the loader and hoe will get loose and the bushings will need replacement but generally not in a 1,000 hrs if it's been regularily greased. 2,000 yah, I'd think that would be a reasonable expectation.
AKfish
I've disregarded the Deere 110 because on the Kubota web site it puts the TLB weight of the 110 at about 8,100lbs. On the JD web site (Product Specification for 110 TLB) they only list the weight w/ the loader, not the BH, and that's about 7,300lb.
Yes, I figure it's on the small side, but then so are my expectations.
The hoe on the B series is about a foot and a half less digging depth than the L35-39. Not the same hoe..
AKfish
That's good to know - but is the hoe the same on the L35 as the L39?
/edit - I know they are probably different model numbers (L35 seems to be listed with a BT900, versus the BT1000(?) on the L39.
Again, thanks for your input.
/ noobie asking for advice #29
The 8K+ lb is pretty well spot on for the 110 with the thumb and replaceable edge on the front bucket. Yah, it will be right in that range - and I'd guess that the L48 won't be too far off that weight, either with the same options.
Soon as you add the HD buckets front and back, extra lights, thumb, top n tilt, belly pan shields, cutting edge, etc. those pounds start adding up. And the manufacturers always quote the bare bones machine.
I'd be surprised if there's more than half a foot difference in the hoes on the L35 vs the L39. You'd be hard pressed to know which one you were looking at from 100 feet away...
AKfish
Well once again I'm back asking for advice.
It seems that I can add a BH to about anything short of my new TDI, for about $6K
For my previous stated requirements are there any advantages/disadvantages for going for a tractor base machine, like the Kubota B series, versus the Kubota TLB series?
I know I need a FEL and a BH, but I don't know about the other differences.
tia
/ noobie asking for advice #31
Yes, quite a bit; actually.
Head over to a dealership and sit in the seat and fire a few of 'em up! Nothin' better than some first hand information - or maybe - hand's on information.
Best of luck.
AKfish
/ noobie asking for advice #32
tia
The dedicated TLBs are generally tougher than equivalent sized tractors with added BH however they are also significantly more expensive. For roughly (actually less) than the price of a Kubota B26 I purchased a Kioti DK40se with a Woods BH90x. That is not a fair comparison in terms of power as the Kioti is closer to a Kubota L39 but with the only downside being trailer weight (Kioti TLB about 2000lbs more) and manuverablility (Kioti is after all a solid 40hp tractor with a nine foot BH) there were not many advantages to the B26. The tractor for example comes with a fully functional 3PT which as I recall is a pain if even possible with some of the Kubota dedicated TLBs. Don't underestimate the need for a good bush hog or flail mower in land clearing. Even if a B26 is tougher than an equivalent HP tractor based TLB, it is not tougher than something as large as a DK. One big advantage for a B26 would be dealership access and quick resale but the Kioti/Woods will get lots more work done.
Well, thanks so far for all the info this forum has provided.
I finally got my first date with a tractor. Just got it home. Unlike my wife and most of my cars I don't expect this relationship to last. I'm already figuring heck I've got the trailer, how big can I afford next year?
It's a cute Kubota b7610, with 246 hours, it came with a FEL, boxblade an 18' 5 ton Hudson trailer and chains, all made in 2007. On the way to look at it I found a lightly used Woods 6' BH with 4 point hitch.
Rolled all together it'll be about $16K.
Already I know I need a grapple and bush hog. Tractors seem to suck money. :)
/ noobie asking for advice #34
Congrats! Looks like a real nice package and a darn good price! Your patience has been rewarded!
Should make those retirement days all the sweeter! :D
AKfish
/ noobie asking for advice #35
Nice little TLB package you got there. And, you are correct that the trailer gives you room to grow. Spend a year or so using the 7610 and figure out if you really do need anything bigger. It will do a lot of work for you.
You might consider a grapple bucket and a set of rear remotes to control it. If you can do your own work it shouldn't cost you more than $700-800 to add a grapple arm to the standard bucket and run some control lines to the remote. Your loader is not terribly powerful but should work very well with a simple grapple bucket. I'd hold off on QA adapters, third function valves and "real" grapples if I were you as those add more cost than could be easily justified given your 700lb or so loader capacity.
/ noobie asking for advice #36
I agree with Eddie on the TLB as the best option...
The most value for the money in a TLB IMHO is a used Terex 760...
Look at machinery trader and you can find these full sized TLB's used in the 20-30 range...
The Kubota and other compact units are not in the same class as these units weigh in @ around 17K pounds...
If maneuverability and hauling is more important to you then the compact TLB's are a better option...
TEREX TX760, Used TEREX TX760, TEREX TX760 For Sale At MachineryTrader.com
<snip>
You might consider a grapple bucket and a set of rear remotes to control it. If you can do your own work it shouldn't cost you more than $700-800 to add a grapple arm to the standard bucket and run some control lines to the remote. Your loader is not terribly powerful but should work very well with a simple grapple bucket. <snip>
I'm seriously considering getting the grapple after the BH, especially after reading your threads. What is required to "do my own work" for adding a grapple and do you have any links for bucket top grapples?
tia
/ noobie asking for advice #38
tia
There are several options available. The easiest to install are bolt on bucket grapples made by ATI, Add A Grapple or WR Long. I haven't priced those recently but I'm guessing $600-800 for the kit. To install you really just need to follow directions, drill a few holes in the side of the bucket and then assemble.
More involved but less money are the grapple arms available from Tatro, "Thumb" and a few others on eBay. I believe those are still available for $350 or so. The potential downside is that these require reinforcement of the bucket upper lip and welding (or bolting). Most people will weld these onto the bucket lip but it is possible to bolt them on if you don't weld.
With either type you still need to rig hydraulics to control the grapple. There are many threads on that subject but basically you either need to get a third function valve and tap into the power beyond circuit of your FEL controller valve or install a set of rear remotes. Costs for a third function valve depend on whether you are buying a fancy (and very nice) kit from WRLong for about $800 or learning enough to buy the parts yourself from internet discount sites for about $300-400. The alternative is a set of rear remotes which can be installed typically in an afternoon without too much trouble using a kit obtained from your tractor manufacturer (most cost about $300-400). With either option you also need to measure for and purchase a number of hydraulic hoses with appropriate fittings which can be done either over the internet if you are well versed in options and terminology or more easily accomplished by visiting a local hydraulic shop.
I think it is safe to say that nearly everyone is a bit intimidated by hydraulics the first time they think about modifying something on their tractor's system. However, in the end it is not highly technical work at all but rather a matter of understanding the basics and proceeding only when you become confident you know what you are doing and why. Other than that understanding, it requires only a set of wrenches and the correct fittings/hoses/valves.
/ noobie asking for advice #39
You know, with my experience with skidsteers (track and tire) I liked the Deere best. Im not sure of its price but you might want to look at the Deere CT315 or a used CT322. Check out The Skid Steer Smackdown! and see ho much nicer the Deere is. Very easy to service because you can push out a pin from inside the cab and lock the loader in raised position. Then you open the back door and lift the top cover. Then remove both side panels and you have total access to the engine. To get under the cab, all you have to do is unscrew two bolts and it easily goes up. When my dad and step mom were looking for a Compact Track Loader, we went all over. That night I showed them the skidsteer smack down and Deere outlifted the new Bobcat T320 and new Cat 297. Deere packed lots of power into their CT332 since it camn gracefully pick up a 6000 pound pallet off a semi and set it on the ground. When we went to Bobcat of Portland, they compared the CT322 to the T190. I did some research and it is closer to the T250. look at the CT315 and a used CT322. My dad and step mom got their CT322 for 30K along with a tilt trailer to haul it. Can you believe im only 13!:D
/ noobie asking for advice #40
Your doing a good job Johndeere! I love John Deere equiptment but I haven't looked into their skid steers yet, you have opened my eyes though!
Thanks
I have a ASV rc-100 & is very powerfull!
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
LOAD OUT AND SHIPPING (A65579)
LOAD OUT AND...
Caterpillar Traxcavator service manuals (A63117)
Caterpillar...
