CK 25 gear, injector pump
/ CK 25 gear, injector pump #1
RADDAD50
Sonoma County, Calif
CK25 Gear, year 2006
On the side of the injector pump there is plate with four bolts. Mounted to this plate is 90 degree elbow with a rubber plug that is painted orange, is there supose to oil or something inside. I ask because all other oil filter holes on the tractor are painted orange??
/ CK 25 gear, injector pump #2
I just had my injector pump out of the engine and removed this side plate during the process. It is an access plate to see the fuel rack inside the injector pump. The housing that this plate is attached to is actually part of your engine block and that plug could be used as a point to fill the engine oil. Most people just use the one on the top of the valve cover because it's easier to get to.
/ CK 25 gear, injector pump #3
Had the same question,according to what I was told,pump is oiled by motor,and yeah,that orange plug is another place to add motor oil.
Thanks for the information. Does anyone no the cost of a new injector pump for a CK25. :(
/ CK 25 gear, injector pump #5
About any kioti dealer should be able to tell you that.
/ CK 25 gear, injector pump #6
Sorry to say but you are going to probably cry over this one:(. You are looking at about $850.00 :eek: for a new injector pump.
Mrs. Tractor, well first I'm going to try and see if the Kioti people will stand behind the EPA warranty and replace the pump. Second the tractor is only 3 years old and has only 300 hours on it, these injector pumps should not be failing at 300 hours. Third does anyone no if there are parts available such as the plastic gears inside the pump.
/ CK 25 gear, injector pump #8
I'm sure there are parts inside that can be replaced. You need a good mechanic sounds to me like.
/ CK 25 gear, injector pump #9
If you can change out the pump yourself, you're probably better off, money wise, doing that. Labor rates are astronomical, and you end up with a used pump after-all?????
I don't have a problem rebuilding a pump with only 300 hours on it that failed because of some plastic gears. These pumps are no very complicated inside.
/ CK 25 gear, injector pump #11
Just thought since you was asking whats inside was a reason you might need a mechanic.:D
Guess your sure it is the pump,you never did say.Cause 300 hours ain't much,did you buy it used ?
No problem Greenmule :D, I now have the pump sitting on my bench and I found the same problem as Lexgs did the plastic gear stripped and a piece got stuck in the fuel rail. This pump is really very simple compared to some of the high pressure pumps I have rebuilt from Germany on our bottling lines.;)
/ CK 25 gear, injector pump #13
This is the first I have heard of these failures on the M27 tractors (CK25/27/
30/35). I see from the parts book that there are no FI pump internal parts
listed, so you may not be able to avoid ordering the whole pump. There is
an external gear on the governor sleeve that can be ordered as a sub-
assembly (#5). Is that the gear that failed? Please post pix of the failed
part(s).
/ CK 25 gear, injector pump #14
If you are going to pull the pump then you may want to try the trick I just did and turn the plastic gears 180 degrees and use the good side that is not stripped. Make sure you clean out all the broken gear teeth because this
is what jams the rack. Do one injector cyclinder at a time since thay are fitted to the bore and you should not mix them. After removing the roller tappet, spring and washers you can see the gear to remove it. When pulling out the injector piston, note which way the slot on the piston is pointing. It can go in two ways but only works one way.
You need to time the gear to the rack by aligning the samll tick mark at the end of the oblong slot with the scribe line on the rack. It is very important to get this right or you may have a runaway engine when you start it. After
re-installing the pump you need to bleed the air from the injector lines by cracking the nuts at the injector end by
about one turn. Crank the engine until you see fuel leaking and then tighten the nuts. It should fire right up. I would have something ready to block the air intake just in case something goes wrong and you need to stall it.
Thanks Lexgs for all your information. That was going to be the next thing I was going to do but as it turns out I just heard from my dealer, he called Kioti and told them the problem. They said they are aware of this problem and that there is excessive wear inside the pumps being caused by the new low sulfur diesel with is not giving enough lubrication to the pumps. They are recomending that a 1/2 quart of ATF be added to each tank of fuel. Long story short they are going to replace the pump and pay for the labor (not transporation to and from) with a new pump that should not be a problem with the low sulfur fuels. I'm not sure if California has diesel fuel different from the rest of US. I no this is going to raise alot of questions about your own equipment and the injector pumps, but this is what I was told by the head mechanic. :)
/ CK 25 gear, injector pump #16
I feel that your dealer may have misunderstood the Tech Dept for KIOTI, all the times I have asked about additives I was pointed to name brand additives. I do know that truckers have been using old engine oil and trans fluid but it is only if you are concerned about price, and in that case it could be used. I rcommend a quality additive, I've been dealing with fuel systems for 15 years and I beleive that the dealer doesn't really understanding what was told to him, by KIOTI you may want to have him check that info again. Also you may want to question the reputation of the dealer as well as their standing with their brands! They could be on the out's with them and trying to drag KIOTI's name through the dirt as well. I suggest you contact KIOTI directly for a better understanding of what the dealer has told you.
1-877-GO-KIOTI
/ CK 25 gear, injector pump #17
Don't add ATF to your diesel, ATF is not deisgned to be burned in an engine. There are other lubricity additives made for this purpose and I have grown quite fond of using 2-stroke oil in my diesel ford pickup with very noticable results.
The good news is that I have been running regular LSD off-road diesel that should still be good plus powerservice additive.
So to those in the know.... is it even possible that the lack of lubricity from the new ULSD could cause this type of damage? I have 767 hours on my OEM pump and don't want a failure.
/ CK 25 gear, injector pump #18
I don't think I'll be adding any atf to my desil,put power service in it now. But if pump goes its got a good warrenty.
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2008 Yale GLP070VXE 6,500lb Propane Forklift (A61572)
2008 Yale...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
1761 (A58375)
1761 (A58375)
