Oil & Fuel New Problem Oil leak on TN75D
   / New Problem Oil leak on TN75D #1
AndyMA
Elite Member
Windham County, Conn
Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
Ws using the TN today and noticed a puddle of oil under it when I moved it. It appears that it i scoming from the PTO area. I can not see well because I need to drop the PTO back hoe to see better. Does anybody know how much of a deal it is to replace the seal on the PTO?
Andy
   / New Problem Oil leak on TN75D #2
I wish I could help you but I have a similar question. I noticed my front axle is leaking oil on my TN65 and I was going to ask on here if anyone else has had to fix this problem on their TN and if there is anything I should worry about before I tear it apart.
Also, it is a very slow leak so I am keeping an eye on the level and hope to fix it after I am done with planting but before haying starts. Is this an ok plan or should I fix it immediately to avoid any other problems? Sorry to steal your thread Andy but hopefully we can both get answers:)
   / New Problem Oil leak on TN75D #3
Dont know, but probably it isnt that. Probably from the BH PTO accouterments. Give it a wash then run it and watch it.
larry
I just ordred a $10 seal which appears to be easy to install. Hope that is all it is.
Andy
Andy
Actually easier than that. One of those pesky bolts holding the rigid lines from the rear remotes to the loader which seemed tight wasn't tight enough. A quick wrench and voila, no more leak.
See picture, Bolt lower left is the one leaking and I do mean leaking.
Andy
   / New Problem Oil leak on TN75D #6
I am glad yours was an easy and cheap fix. Mine is looking a little expensive :(
Me too. Do you have service manuals? I have a full set that I bought on eBay from a dealer who went out of business. If you need any pages I could scan and send them to you as PDF's
Andy
   / New Problem Oil leak on TN75D #8
Exactly where is it leaking?
   / New Problem Oil leak on TN75D #9
Sorry Rick. I wasn't more specific in my original post. It is leaking out the end of the right side of the axle tube itself right where the knuckle is for the hub. According to the NH parts site there are two bearings there with the seal.
   / New Problem Oil leak on TN75D #10
Andy
I don't have any service manuals so far as I have never needed them. This tractor has been quite solid ever since the first year. If you could scan the pages dealing with the front axle I would appreciate it. I have to pull the front right wheel off then remove the hub and everything should be fairly simple and straight forward from there on but I have never done this repair before so I don't really know what to expect. Thanks for the offer.
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
2023 FORD F-250 (A58214)
2023 FORD F-250...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
