two_bit_score
- The demo started by removing all the interior wall coverings which were dry wall, bead board, plaster and lathe(a real pain) or t&g paneling. In my case I left the roof and exterior coverings in place to keep the heart pine flooring dry
- Once I had a dry looking weekend I knocked off the exterior wood siding from the inside out
- Next, I started on the roof removing the tin and purlins and pushed over the rafters
- Then I pulled down the chimneys a long rope and the tractor which was actually much easier than expected.
- This left me with the timber frame and floors. I pulled up the floor on the second floor one board a time on the bottom floor I cut the joists at each end and used a sledge to pound down on the joist which pulled them away from the flooring so I didn't have to pull the first floor up one board at a time. I could do this because these floors were through nailed using locally produced iron cut nails that slid out of the wood rather easily.
- Finally I cut some of the tenons on the timber frames and pulled them down in sections with a rope
- All this work was done by hand with a hammer, sledge, 48" Gorilla Bar and sawzall. The pallet forks were awsome because I could stack directly on them, drop my load on a hay wagon, haul it to my storage building and unload with the pallet forks again. I also used them to lift and move the heavy beams. Don't think the
grapple would have worked as well for moving the stuff around as the forks
- I hope to sell most of the heart pine and use the oak and tin on other buildings on the farm. I traded the "wavy glass" windows to my neighbor for deer corn. I saved the doors, fireplace mantles and interior trim to either sell or reuse. Burned the rotten and unuseable wood
Ranger Rick
- House was estimated to be around 100 years old, all the wood except for the sills was sawn so probably not too old. Supposedly was a trading post at some point for the Iron Furnace next door that was built in 1863 to supply the Confederate Army with iron when their other sources of iron were cut off. I have attached a picture of the stump that the house was built over, I assume they cut down the tree and just built the house over it.
JB4310
The mortar if you can call it that just crumbles into dust. The brick is interesting, we have found peoples names scratched into some and a childs hand print in some. Been giving the brick away, should probably see if I can get something for it, I have a lot.
