OPERATIONAL TIPS FOR NEWBIES
/ OPERATIONAL TIPS FOR NEWBIES #1
workinallthetime
Tulsa, ok
L45 TLB, ZD326P
Last night my wife was telling me a story about a friend who rented a tractor and it about caused him a devorce. He was unable to fill the bucket full of loose soil, trenched up the yard, rolled a tire off hte rim (probably not his fault) and managed to hit the house with the box blade.
So much of what we talk about on here is pretty advanced or very specific si i thought i would start a thread about just general operation and our tips and tricks.
Come on fellas lets tell the newbies how we do it with a smile on our face :D
IMO
With a new machine take it slow 1st gear 1/2 throtle until your comfortable
loading the front loader - flat bucket with a curl as you load 4x4 on
general driving around the yard 2x4 mode
use the parking brake
/ OPERATIONAL TIPS FOR NEWBIES #2
I agree taking it slow and learning is the best policy. Another good tip is approach hills up and down and not sideways! I too am a fairly new operator about 2.3 years and almost 200 hrs. and I have learned a bunch by practicing and the help of all my fellow TBN' ers and I must say I am pretty good now and other more expirenced operators have commented on some of my completed projects.
/ OPERATIONAL TIPS FOR NEWBIES #3
A relative Newbie myself. Here's a few:
1) Respect the PTO, and all moving parts!
2) Use seatbelt and ROPS
3) Read the manual, then read it again for specific jobs
4) Pull with the drawbar, not a higher point on machine
5) Think before you do
6) Beer after tractor work, not before
7) Listen to the guys who've been around equipment
8) Learn when your machine isn't the right tool for the job
9) Quick attach/skid steer type bucket mounts are great, as are i-Match style hitch adapters.
10) If you don't know, ask on this forum!
/ OPERATIONAL TIPS FOR NEWBIES #4
Common sense.....
Another thing i found was lowering the tire pressure in my zd326 (ztr mower) to 12-15 psi, this kept my tires from slipping as much and imprved the ride greatly. They had close to 30 in them when delivered from the dealer.
/ OPERATIONAL TIPS FOR NEWBIES #6
I think I have read that one of the common injuries is getting caught in a rotating parts, such as PTO's and tires. I have been driving along and been tempted to knock a chunk of mud off the tires while driving, don't! Also watch for pinch points, such as on the end loader, 3 point hitches etc.
Wear your seat belt.
Use your ROPS if it foldable.
I think for general operating, anyone just starting out will catch on, but saftey is the issue for the new owner. You don't want to learn the hard way. I have 150 hours on mine, so I'm really still a newbie. So far no broken bones or broken parts.
/ OPERATIONAL TIPS FOR NEWBIES #7
I'll start with these good ones and add to them.
11) Go slowly with FEL loaded or on slopes, especially cross slope.
12) ALWAYS have plenty of weight on the 3ph when doing FEL work. Good idea to load the rear tires, but they're not enough.
13) NO NOT maneuver in a door way. Do your maneuvering before the doorway and get properly lined up before going into the door way.
14) Put PTO in neutral or forward (whatever position on your tractor to make it free wheel). Then support the PTO shaft of the implement with a tension cord, chain or whatever you find easy to use to take some of its weight off. Then put up against the shaft. Turn shaft on tractor by hand until you find the splines meshing. Then push on.
15) Tug that PTO both to & fro after pushing it onto the shaft.
15) Put implements on castors and preferably on a hard floor to store them.
Ralph
/ OPERATIONAL TIPS FOR NEWBIES #8
16) Put implements on castors and preferably on a hard floor to store them.
17) When using an implement (loader, backhoe, grapple, etc) on are near trees look up before jarring the tree. Things falling out of the tree on your head/equipment is not good.
18) Be mindful of your center of gravity keep it low and slow.
/ OPERATIONAL TIPS FOR NEWBIES #9
19) When traveling across a slope with a FEL Keep the bucket low,a raised bucket will cause you to turn over on a hillside.
20) Be aware of dips and swells in the ground this can also cause a rollover.
21)Keep the equipment in good working order,safteys,brakes, maintenance etc.
/ OPERATIONAL TIPS FOR NEWBIES #12
Great thread...! hope to see some task specific tips etc...
it can't be said enough...ROPSs do no good without the seatbelt use it!
/ OPERATIONAL TIPS FOR NEWBIES #13
31) Wear a cap or hat. You'll need it when you stir up a yellow jackets/hornets nest with the mower!!! ;) :(
/ OPERATIONAL TIPS FOR NEWBIES #14
28) Don't ride wearing just flipflops or sandals!
Please, please, please! Think of the neighbors.
Good luck, Wm
32. CALL LOCATE SERVICE BEFORE THE B/H TOUCHES THE GROUND.
33. when possible start french drain trenches from the dump end, this way you can make adjustments to depth, backfill as you go.
34. Make your family, friends, anyone that may be around you while your operating your equipment aware that they should NEVER be behind you.
more to come
/ OPERATIONAL TIPS FOR NEWBIES #17
One thing that I have found in tractors as well as life in general:
35. There ain't no cure for dumba&& and there is no substitute for common sense.
/ OPERATIONAL TIPS FOR NEWBIES #18
Not sure if it's been mentioned yet but always try to go up/down hills with your load uphill.
Full fel bucket forward uphill, back down hill.
Big bushog and small tractor going uphill might not have the best of steering.
Use lower gear for enging breaking going down hill.
Don't ride the clutch. It wears them out prematurley and when a clutch goes out goung down a hill with a big load behind you it's the same as putting it in neutral and going for a ride.
/ OPERATIONAL TIPS FOR NEWBIES #19
Some one mentioned about getting caught getting off of small or tight operators area..I have a Kubota CUT and with all the levels on it in the fenders have found it a great placed to get caught. Have a pair of shorts not ripped getting off one day was heading for me head landing first. Long pants only now and have had a lever to catch a front pocket last week.
In my part of the world PTO and roll overs are the killers. Finger issues are often hooking up. Be sure if you have someone moving the tractor for you to pin an implement you are not between the two.
/ OPERATIONAL TIPS FOR NEWBIES #20
36. Careful while raising loads in the FEL, going too high could result in contents of bucket landing on hood of tractor or worse yet, on the operator.
Mark
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2022 EZ-GO ELITE...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
