TEETH on FEL
/ TEETH on FEL #1
laen64
Gold Member
Ashford Alabama
Bobcat CT335 SST;FERRIS IS 1500Z 25hp 52"
Would you suggest the use of the Teeth or would I really be happy without them. Surely I'm new and considering all that I want with the initial purchase.
Please Give Feed Back.
/ TEETH on FEL
Please Give Feed Back. BX2660?
/ TEETH on FEL #3
If you want to dig with your FEL, you want bucket teeth.
/ TEETH on FEL #4
I bought a toothbar with my first BX2200 five years ago. Took tooth bar off when I traded it a year later and sold bar later. Haven't bought another one since then. Probably won't save any money by buying with tractor unless you make your deal then ask if they will give you a toothbar at that price.:) Try using the tractor without it and then decide whether you need it. If you can do what you need to do without it then put your dollars into a boxblade. I mainly bought toothbar to save the edge of my bucket but I used a B7800 for 3 years without one and used it alot with little wear to bucket edge. Jobs and soil determine implement needs. Hard and/or rocky ground can be dug somewhat easier with a toothbar. Digging decent dirt or working a pile I prefer no toothbar.
/ TEETH on FEL #5
I agree 100%. I even used mine when I was splitting wood.
/ TEETH on FEL #6
Depends on what you want to do with the FEL. I rarely dig with mine but carry things all the time. The extra distance the teeth stick out helps immensely with what will stay in the bucket, especially branches and logs. Never regretted the purchase.
/ TEETH on FEL #7
I purchased and installed what is called an bucket edge guard.:D It's kind of like a reverse tooth bar. I had installed one on by BX23 and liked it so well that I just installed and painted one on my new B3200 TLB. It protects your cutting edge of your bucket when plowing snow on blacktop or stone driveways. It also helps when your trying to pop out rocks that seem to grow in lawn. But I really believe it adds strength and about 5" to your buckets edge. If you can see in photos you can too hang items from teeth.:rolleyes:
DevilDog
/ TEETH on FEL #8
Wow devildog1...do you WAX that bucket!!! I have not seen one of those edge guards...where did you get it from??
Dean:D:D
/ TEETH on FEL #9
I built a tooth bar for my bx 23, cost me about 90 bucks, and about an hour of my time. When I traded the bx 23 for the b3030 i resized the toothbar and use it on the 3030. We dont have soil here just rock and clay, the tooth bar is great, a road i has been working on 5 feet at a time up the sie of a hill was suddely finished now that the tooth bar would flip the rocks out.
When Im handling loose material that requires the "finished" look when im done the tooth bar is off but the rest of the time its on. Works great for brush, seperating vines from mother earth, digging, plucking rocks, holding material in the bucket, haulin logs, and just general tearing up the surface of what ever it comes into contact with.
2 things i have to have, teeth for my bucket and a thumb for my hoe
/ TEETH on FEL #10
I love my toothbar. Try to get them to throw it in the purchase. We have tons of Clay and Rock but the tooth bar also works wonders on popping out small sapplings and hooking onto a root ball. If you get an itch you can't reach, you can also hop off the machine and rub up against it....:p:p:p Keep your minds clean now!
/ TEETH on FEL #12
Hey Deano,
No wax on bucket, it's brand spanking new, although the the hood fenders and rims do have a coat of Mothers on them. I purchased the edge guard from Carvers of NC, they are a dealer on this site.
DevilDog
/ TEETH on FEL
Hooah! everyone. I will have this added after the settled price. It may not be for a while but you bet there will be pics posted.
Thanks
/ TEETH on FEL #14
I use my buckets for smoothing the dirt after I get done, so the no teeth make for a smoother finish.
/ TEETH on FEL #15
I bought the WR Long flat tooth bar just for that reason...the best of both worlds!!
Deano
/ TEETH on FEL #16
depends what your doing i put a wr long tooth bar on comes off with 2 boltsi have a 5 foot bucket on a B 7800 it is about 300.00
/ TEETH on FEL #18
As mentioned, the tooth bar is more of a hinder than a help when working loose dirt. Even digging, the sharp straight edge of the FEL bucket makes a better and faster cut.
But for many jobs, it's the cat's meow.
..pulling up fence posts, with a 6 ft length of chain to wrap around the post, you have good stout places to tie onto the bucket with the chain.
..lifting/carrying anything else with a chain wrap.
..combing branches out of tall grass, and general brush-pushing.
..popping burried concrete blocks or mobile home pylons out during demolition work.
..just about anything else in demolition work - the tooth bar lets you carry more and hook onto stuff more easily
..popping out small stumps (if you can get a good angle on it; not near as good as a backhoe, of course, but better than a shovel and chain saw).
..take a run at a stack of railroad ties with the tooth-bar installed, you can get two, maybe three, railroad ties onto the FEL for transport; without the toothbar you have to dismount and hump the tie onto the bucket, and you can only carry one at a time.
/ TEETH on FEL #19
A toothbar at least doubles the utility/usefulness of the FEL....
install it with bolts that can be removed... takes about 5 minutes.... and you can smooth without the bar installed, if that is what you need.
The bar is installed on my FEL about 98% of the time... it is an exception when I need to use the lip of the bucket for smoothing things out. Others have well pointed out the features of extra bucket capacity, holding capability, digging capability and chain attachment for lifting.
/ TEETH on FEL #20
Why would i need a tooth bar when i have both a BH and a Tiller?
They are darn useful - a removable toothbar is one of the best bang-for-your buck things you can put on a tractor. And I have a BH and a tiller, but I use them for other stuff.
Those interested should do a search on here - have been a fair number of discussions.
