Hydraulic Limb Snipper
/ Hydraulic Limb Snipper
Kool, how did it do ?, Any action shots ?
Curious as to how big it can cut, sure 5" will fit, but doubt that size cylinder has enough force to do the job.
Maybe not with the angle I have on the cutting side now, about 45 degrees. I do plan to taper the cutting edge similar to an axe.
/ Hydraulic Limb Snipper #23
Mr. Brown, The proper way to prune a limb is just to the outside of the branch collar. That area contains lots of active growing cells and if pruned just outside the collar, the cells will eventually heal over the wound and the result will look like a small closed eye on the bark.
You know what, I have never used that word before, and I did not know what a branch collar was and had to look it up. So here it is.
Prune to the outside of a tree's branch collar for fast healing and good tree health. The branch collar is the swelling located at the base of the branch, where it arises from another limb or the trunk. The branch collar is like a hospital isolation ward; it houses protective chemicals that help keep diseases from invading the parent limb. When removing a branch for any reason, leaving that branch collar in place shuts out any passing pathogens.
/ Hydraulic Limb Snipper #25
J_J,
If you haven't modified the blade to be more like an AXE, let me know. I think my mill would be the perfect way to change that angle to what you want, rather than a grinder. We should be able to do it without too much problem if you bring it over. No charge.
David from jax
Hi David,
Thanks, I just might do that.
/ Hydraulic Limb Snipper #27
Very cool and well thought-out attachment JJ.
I took some pics of a right-of-way saw when they were doing the power lines in my neighborhood. Reminded me of Mad Max. They don't seem to attempt to cut to the collar but it makes a clean cut. Probably chops all the way through before the branch starts falling.
/ Hydraulic Limb Snipper #28
Mad Max, that great man.
/ Hydraulic Limb Snipper #29
Hey J_J,
Your Limbshear is perfect for my needs, really like to build one. Can you PM the hydraulic specs and any drawings for one that can be built. My brother works at a steel supplier and I can get any type or shape of steel.
I certainly would be indebted to you!
Thanks
Kneedeep :log: :thumbsup:
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
JCB 416 WHEEL LOADER (A65053)
JCB 416 WHEEL...
2007 Freightliner Semi Truck (A66285)
2007 Freightliner...
2022 EZ-GO ELITE...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
