Ford 2 bottom 101 plow
/ Ford 2 bottom 101 plow #1
wanna
Member
orleans county new york state
jd 1070
Hi guys need some help i have a two bottom ford 101 plow . The problem is the front bottom always trips i can reset it but then it trips agin and agin in a short distance when its not triping it plows perfect.P.S. its a14 inch plow
/ Ford 2 bottom 101 plow #2
Farm with Junk will know this one, give him a few days to chime in here he owns his own business, busy man. He knows his stuff, he must be older then dirt;) with all the knowledge he has
/ Ford 2 bottom 101 plow #3
It's been ages since I've adjusted the "trip resistance" on a 101, so I'm a little foggy on the technicalities, but there is such an adjustment. I'll scout around in my pile-o-manuals and see if I can find a Ford 101 plow book. It'll be in there! The mechanism that allows a plow to trip can wear, or it can become rusted and/or dirty. If so, they don't always snap back to locked position as they should. May be that problem too.
/ Ford 2 bottom 101 plow #4
You use a 1 1/16" open end wrench from the back side to lift the locking cam lug, reducing the tension on the spring. While you have the lug held up, you turn the spring guide clockwise to tighten the spring which will increase the trip tension. Turn 2-3 turns at a time and then test. I have the full manual in pdf format. If you'd like a copy, PM me your email address and I'll send it to you.
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
Giyi GY-CWG72 Quick Attach Curved Wood Grabber (A60463)
Giyi GY-CWG72...
Giyi GY-TB47 Forklift Telescopic Boom (A60463)
Giyi GY-TB47...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
CFG Industrial MX15RX (A60463)
CFG Industrial...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
