Hydraulics jerky
/ Hydraulics jerky #1
sarti
Central Illinois
Kubota L3901 BX2670
This is probably in here somewhere But I can't find it. After changing oil and filters on hydro my transmission is real jerky and loader moves real slow.
Do I have air in the system and if so, how do I bleed it out? I have a B2630
Thanks
/ Hydraulics jerky #2
I would make sure you added enough oil back to the system. It could be low on oil or a filter issue...
/ Hydraulics jerky #3
If you have enough oil... I think to purge air, you max out the curl and lift in both directions a couple of times.
/ Hydraulics jerky #4
Thanks
Assuming your fluid is full up, I think your have a suction leak - probably at the replaced filter. Once you eliminate air getting into the system, however it is, the air there will be purged in normal operation.
larry
