motor help
/ motor help #1
tlbuser
lower part of Md.
JD310, ASV RC-100
I need to purchase a 11-12 cu.in. A frame with a 7/8 x 13 tooth shaft. Anyone know where to find the right number codes for the different manufacturers?
/ motor help #2
I looked at Surplus Hydraulics and didn't see any. If you order new from the manufacture, you will pay big bucks, but you can specify the shaft desired. The other option is to purchase an adapter, that will convert the 7/8 13 T, to a more common shaft. However if the receiver is something like a hydraulic winch and has 7/8 13 splined input, then you are limited. Search Ebay, Surplus Hydraulics, and Baileynet.com.
Can you tell us how it is being used?
2014 Dodge Caravan Van (A64557)
2014 Dodge Caravan...
6ft Teakwood Indian (A65583)
6ft Teakwood...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
Rigid Pipe Threader & Pipe Stand (A62613)
Rigid Pipe...
2014 Infiniti QX60 (A62613)
2014 Infiniti QX60...
2001 UNKOWN  GOOSENECK PUMP TRAILIER (A65643)
2001 UNKOWN...
