Thermoplastic Hydraulic Hose?
/ Thermoplastic Hydraulic Hose? #1
charlz
Elite Member
Meridian Idaho
Kubota B7100D
I popped a hose the other day on my 32 year old Kubota backhoe attachment (actually rubbed through). The dealer said the PN was no longer available from Kubota so I pulled the hose and took it to a local hyd shop. Turns out most of the hoses on my hoe are thermoplastic and not the steel wired stuff. Cost me $35 instead of $50 to have a hose made up. Stuff meets SAE 100R7 and is rated up to 2750 working psi (my hoe relief valve is 1500). Has a much smaller bending radius which is good on these small tractors.
What cons if any are there to this hose? For being on there 32 years a lot of the hoses have jackets coming off etc but otherwise work fine.
/ Thermoplastic Hydraulic Hose? #3
I think you may have just answered your own question ;)
32 years and they're still working... 'nuff said!
/ Thermoplastic Hydraulic Hose? #4
The thermoplastic hose is good stuff. It's used in a lot of different applications. Where it really shines is when it goes over a pulley. That stuff can flex all day and last as long as anything. The hose shop probably made you the same thermoplastic because that's what you brought in. A lot of people tend to think that it's plastic junk but it's actually good stuff. I have a hand operated crimper that I can use on the jobsite to make hoses on the spot. It's a more popular brand, Synflex. You won't be disappointed.
Thanks for the input. I was curious when I couldn't find any mention of it on here since it is apparently cheaper, bends better and meets the psi requirements of these small tractors. I saw the crimper at $299 plus the cost of dies... definitely cheaper than a crimper for 'regular' hydraulic hose.
40' High cube 6 door Single use Shipping Container (A64194)
40' High cube 6...
New/Unused 12V Diesel Pump with 50ft Hose (A65583)
New/Unused 12V...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
1990 Chevrolet P6000 Command Center Step Van (A64556)
1990 Chevrolet...
KMC 3PT W/ 3 X 3 TOOL BAR (A64278)
KMC 3PT W/ 3 X 3...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
