CK 30 RPM's
/ CK 30 RPM's #1
jimmyj
Elite Member
Ontario Canada
Allis Chalmers 616 (Two) and a Kioti CK30 HST with loader and backhoe
The manual for my new CK 30 HST has a statement in it about what RPM's to use for various tasks.
It says basically, "refer to the table below for RPM specifications in various uses"
........then, of course, there is no table in the manual.
I know the rear PTO RPM marker is about 2600 RPM's and I tend to run about 2000 for most tasks with travel or using the FEL after some of you posted some advice for me earlier.
Any other RPM advice out there?
/ CK 30 RPM's #2
No majic settings, except when using high RPM implements like mowers, tillers, and chippers. For these run at PTO RPM mark. For other things you can run lower and or vary using the foot throttle. However, on some HST's it is suggested that you always transport at or near full RPM's. I think this might reduce wear on the tranny. Your loader will also cycle faster at high rpm.
/ CK 30 RPM's #3
I have the CK30 with the HST also, and my dealer told me to pretty much always operate the tractor with the RPM at the mark on the tach. He said I could cause problems to the hydro if i drive it at a lower RPM.
/ CK 30 RPM's #4
On the HST Tractors, minimum rpm is 2000 to provide the proper charge pressure in the hydrostat. Starving the hydrostat by not producing enough charge pressure it's a good thing for the hst.
/ CK 30 RPM's
Thanks very much guys. Very helpful.
/ CK 30 RPM's #6
Wow, did not know about the minimum 2000 rpm for hst. but I pretty much have mine about that if driving, but drop down to 1800 or 1900 for the backhoe, any higher and I bounce around a little to much.
joe
/ CK 30 RPM's #7
I pretty much always run lower like 1800 for most work unless I am in a hurry or need extra power and then run up to 2000. When using the PTO mower, the RPMs are set to PTO540.
I also have never heard of this minimum of 2000RPM. That's pretty rev'd up and noisy.
/ CK 30 RPM's #8
I run mine where it sounds "sweet" that's between 1900 and 2100 rpm. If I'm usinf the pto I use the redline but most of the work is done in the sweet spot.
/ CK 30 RPM's
It is interesting as this goes on - I was doing the same as the last 3 posters. But, MichiganIron is a very knowledgeable dealer so I would not discount that advice for sure. Sad that the manual is missing the darned table.
Yesterday I ran at 2300 RPM and it was still really smooth. I dont' want to mess up the HST although I will be putting the BH on soon and want to see how it feels. (Have never really used it as I just got it before the winter freeze up).
/ CK 30 RPM's #10
Hmm, this is the first I have heard of a 2000rpm min for HST use. I typically run between 1500-1800 as it gets the job done with minimum noise. The only time I run at 2000 or higher is when I want to get somewhere in a hurry and I am using high gear. I don't doubt what MI says, I would like to understand more the why such high rpm is required.
/ CK 30 RPM's #11
JimmyJ I hope you are not planning on too much backhoe work for a couple of weeks yet as there is still a fair bit of frost in our area, I have mine on and did a couple of test holes last week as I wrote in another thread I had a tough time digging due to 1 1/2 to 2 feet of frost. Gary
/ CK 30 RPM's #12
I Had suggested in an old post that HST's should be operated at or near full throttle and some said that it was not necessary. As I didn't own a Kioti HST I didn't argue back. But, the manual for my John Deere HST clearly says to run at full throttle. Anything much less and you can hear the tranny straining. Sure makes sense because HST's rely on hydraulic pressure.
I even keep my rpms up a bit (>1500) all the time for my manual tranny. Just seems to reduce any tendency to ride the clutch and the tractor operates more efficiently too.
/ CK 30 RPM's #13
I do the same as you Jim. I tend to do routine tractor chores at 1500-1800 RPM as that is plenty of power and the engine is quieter. Mowing starts at about 1800-2000 and only with heavy grass or serious bush hogging gets me up to PTO speed. I also use the BH at 1500-1800 most of the time.
I must confess I don't quite understand the relationship of RPM to power in the hydraulics. I may be incorrect but I thought that the hydraulics are always at "normal" pressure and that only the gpm changes with RPM. If that is the case (and it is probably not that simple) then the only penalty for running at less than full PTO would be slower function. My experience however says that indeed I do get more power with higher RPM but I don't notice significantly different loader or BH power after about 2000 RPM.
/ CK 30 RPM's #14
Sounds like we need to hear from Wallace and some of the other dealers to get the benefit of their experience and factory training.
I too run lower RPMs for noise and economy most of the time at the 1500 to 2000 "sweet spot"
Since I have over 600hrs on my 2003 CK20, and its mostly heavy dirt work and heavy bushhogging (at 2000-2600), I would like to know about anything that will increase longevity or reduce wear.
Makes me think its time to check the log book, must be about time for another hydro oil & filt change.
Joe48
/ CK 30 RPM's #15
2000 rpm minumum for the charge pump of the hydrostat to properly feed system and keep up with the "losses".
If you look at the performance curve of the engine, it will torque out at approximately 2100 rpm, then fall off slightly above that. Your engine is running at top effciency at about 2100 rpm. Above that is "horsepower", the time dependant measure of how much "work" an engine can accomplish in an interval of time.
/ CK 30 RPM's #16
I understand that you get the most "bang for the buck" in terms of engine power and efficiency at around 2100 rpm. However, I am not clear on how it could be harmful to the HST to operate at say 1500-2000 engine RPM assuming the engine is not lugging.
/ CK 30 RPM's #17
Probably won't.
The HST is a closed hydraulic circuit with a variable displacement pump and fixed displacment motor. With any closed system, there are losses (heat, etc.) To keep the the system operating at the proper pressure and flow, the charge pump continuously supplies a pressure head to the closed HST system. The system is designed to operate with the charge pump pressure head of 90psi. The charge pump is designed to supply the charge pressure of 90psi at about 2000rpm engine speed.
So....to have the HST operate as designed, 2000rpm supplies the proper pressure head. Loss of charge pressure can cause cavitation in the system.
/ CK 30 RPM's #18
Probably won't.
So I understand this correctly, :confused:, the 2000 rpm is "only" for when you are using the HST....pushing, pulling, or just traveling. The bh and pto are independant of the HST and can be run at less rpms if you're not "moving" the tractor. And as always, don't lug the engine down for any operation.
/ CK 30 RPM's #19
Exactly. For BH operation, we usually suggest around 1500 rpm until the customer gets comfortable with the machine. Most of the time, 1800 rpm is enough for backhoe operation.
The 2000 rpm suggested is for proper HST function.
/ CK 30 RPM's #20
I found this thread very interesting and helpful. My dealer told me to always run my DK45 at the highest RPM to avoid damage to the HST.
Informational Lot - Financing (A63689)
Informational Lot...
2014 BMW X1 S28i SUV (A61574)
2014 BMW X1 S28i...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
