quick hitch options
/ quick hitch options #1
MississippiMan
Mississippi
Mahindra 5525
this tired old man needs some help getting a quick hitch rig for his 5525. what do you guys suggest? any brand i should avoid? thank you.
/ quick hitch options #2
Harbor freight has two, one doesn't fit much, the other is what I have and for my 42hp kubota it's fine. I bought my father the same thing for his 5525 and it's holding up ok to and for the price it couldn't be beat. But.. my father is extremely gentle with his tractor and does nothing more than cut the pasture and grade the gravel road. What are your intended uses?
/ quick hitch options #3
Does anyone know which one works and which one doesn't?
/ quick hitch options #4
ITEM 97214-3VGA is the one I have and it seems to fit most implements fine, though some do need a little tweaking. Got my fathers for about $60 with a coupon.
i mostly do the same as your father but i won't say i am especially gentle. i have been know to frequently swing around and hit things with my bushhog. we have a hf store nearby so i will go see what they have. anything sub $100 is surely in my price range for now. i only have a cutter, box blade and a middle buster. thanks.
just check hf and they have them on sale for $79.99 till apr 6. i'll probably give it a shot unless someone has a better idea.
/ quick hitch options #7
I don't think you'll be disappointed for the price. I'm fairly abusive with mine and it's holding up find. The bottom pins that come with it may need to be changed out eventually but find a coupon and tack on to the sale and it's a no brainer!
/ quick hitch options #8
I got the one but I think it is too wide... The Outside measurement was like 32". I may need to cut the top bar down a couple of inches. Going to the farm 4/9/9 and see how it works. Also, I can use the hook at the top but I'll need to adapt something that I can put a pin through... Or can you buy an adaptor??
/ quick hitch options #9
I also have the Model 97214 and love it... strange that they don't push the 3 PT adapter... I called and ordered the adapter "after the fact" ... set me back $8 plus shipping... Had I known, I would have ordered the adapter at the same time as the QH ... Grrrrr
/ quick hitch options #10
Yes they do, but I can not remember the p/n and it isnt' on the website, I believe it's in the paperwork or you can do a search here and find it.
I doubt it's to wide, the problem is usually it being to narrow. You can always shim your pins on the implements out some.
/ quick hitch options #11
Thanks found the information I needed on another thread: harbor frieght quick hitch toplink - TractorByNet.com and BTW the adapters are backordered until May 8th, 2009.
And thanks for the advise about the shims... I just didn't think about that. I only have one implement here (just bought a 5' spike roller for $100) and the hook up for that was too narrow (the quick attach thingy was too wide) but like you said, I could add shims to see if that will work.
did it hook up out of the box for your father or was some re-engineering required?
/ quick hitch options #13
Fit just fine. Had it installed in seconds, then took a couple of minutes to decide on the height for the top hook. Has been working like that for 6 months now.
okay so i went to hf and bought the hitch for $80. the frame looks solid and the paint job seems fine. but the actually catches on the hitch don't look too sturdy so i can see i will have to be careful about hitting things and putting lateral stress on them. maybe i am wrong as i haven't even hooked it up and i'm just guessing. if it works for just a while it is worth the money paid for a try out before i buy something better, if need be.
/ quick hitch options #15
I can understand that, but you aren't going to provide a great deal of force upwards as the arms will move, they don't hold force down.
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2019 MULTIQUIP TOWABLE GENERATOR (A63276)
2019 MULTIQUIP...
KIVEL TRAILER MOVER ATTACHMENT (A64553)
KIVEL TRAILER...
2014 Freightliner Cascadia Semi Truck (A66285)
2014 Freightliner...
