Chipper Chipper Blades
/ Chipper Blades #1
dking
New Brunswick, Canada
Kioti DK45SE / Massey Furguson 165
How often would chipper blades need to be sharpened, roughly in hours? For that matter, how often would you have to replace the blades? These questions are assuming normal use and not feeding any wire or rebar thru the chipper...
/ Chipper Blades #2
I am curious on how you know about wire and rebar in a chipper? :D Or should I not ask? :D
/ Chipper Blades #4
Totally depends on what you are chipping. soft wood, hard wood, how much soil on it. Can be as often as every day or may be several months.
Andy
/ Chipper Blades #5
I watch the hour meter on my chipper and sharpen them around 40 hours. I have gone to 50-60 hours. That is getting a big too long as it is harder on the chipper. Also I rotate the anvil to have a good clean edge for the wood to be sheared when the knife comes down. Gap is another important thing.
/ Chipper Blades #6
On my manual feed Bearcat chipper/shredder I get 10 to 15 hours before it gets hard to push the wood through.
Chris
/ Chipper Blades #9
10 or less usually. Whenever the chipper stops self feeding and starts "tearing" the wood instead of "shearing" the wood. Usually the bark starts peeling off the wood in strips too instead of being cut with the chips.
/ Chipper Blades #10
On my Morbark chipper I run around 10-20 hours on a set of knives before rotating.
I kind of keep a mental note on what I have been running through the chipper, and keep track of the hours via the hour meter.
Keeping the gap adjusted with respect to the anvil is also very important.
If I have even the slightest notion of any metal in the wood, I will set it aside for a burn pile.
It seems to me that a piece of rebar going through a chipper can get very expensive.
/ Chipper Blades #11
Or deadly with rebar.. You only get about 20 hours on your knives? Doing a lot of hardwoods or trees growing in the sand?
/ Chipper Blades #12
I look at it like my chain saw ...... If I am cutting clean green wood it stays sharp longer , If I am cutting dead dirty wood it dulls quicker..... hit metal / rock, not good.
Ronald
Ranch Hand Supply
2025 IR IRET13 ELECTRIC TRICYCLE (A62130)
2025 IR IRET13...
2011 Dodge 2500 Service Truck (A63116)
2011 Dodge 2500...
2022 Husqvarna Z560L Zero Turn (A63116)
2022 Husqvarna...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
