Carrying stuff on your Kubota?
/ Carrying stuff on your Kubota? #1
yeagisyeag
Northern Ohio
Kubota B7100HST, International IH454, John Deere F910
I had a great day yesterday, as I finally got to take my B7100 out to my 18 acres to get started on a long list of projects.
I used my dirt scoop to carry a chainsaw, gas can, bar oil and gloves out to an area where a tree had fallen and was blocking a path. Then I used the scoop to haul the cut up wood back to the front of the property for stacking.
What I kept finding a need for was someplace on the tractor to put various items like water bottle, safety glasses, gloves, camera, etc. A spot that would be clean and protective so that things don't get damaged is a definite must now that I've been out there.
When working in a remote area, how do you transport your smaller, fragile items?
Thanks,
Jim
Here's my B7100 out back in the woods:
/ Carrying stuff on your Kubota? #3
Sometimes in the summer I throw a milk crate on there to hold more stuff. Sometime with a project we'll load the bucket up with odds and ends and establish a staging area to hold stuff. This tray just slides on/off in seconds.
You should think about a FEL...
...but with a little work you could mount a tackle box on that wood carrier of yours.
/ Carrying stuff on your Kubota? #7
I strap my chain saw to the cutter or box blade with a rubber strap. Never had a problem with it. Small stuff like stick on rear view mirror, nylon strap, rags, most used tools like hammer and crescent wrench, clips, pins etc, 12 volt air pump,extra eye glasses and whatever goes in the tool box mounted on the brace behind the seat. 20 foot chain goes in the pvc pipe in my fel. Other tools go in short the fel tubes with pipe end caps. I've got a loper hanging on the fel. Water jug hangs on the fel control lever. I've got a rain coat in the area where the battery is. Don't know of anything else I've ever needed. I can be anywhere from one to five miles from home in the middle of the woods and at one time or another I needed every one of these things and didn't have it and did a lot of walking.
/ Carrying stuff on your Kubota? #8
my dad on his old b7100 used a ammo can and mounted it down to the roll bar behind the seat.
he is getting a new bx24 this weekend
/ Carrying stuff on your Kubota? #9
I just wish my fenders were bigger on the BX. I still am looking for the best place to mount the "Barley" pop cooler. That always seems like the hardest thing to find a place for. HA HA!!!
/ Carrying stuff on your Kubota? #10
I'd like to see how you have the PVC mounted to your FEL. That sounds like a great idea.
/ Carrying stuff on your Kubota? #11
Storage is ALWAYS an issue. I built a wooden tray that sits in front of my steering wheel and is attached to the fel crossbar. This gives me a spot for stuff (tool box, chainsaw gas, etc.) and includes a cup holder. I also have a chainsaw holder on the rollbar. This is an ATV chainsaw holder that I attached to the ROPS (without drilling!). Two chain boxes - one on each side of the FEL mount. A hat/helmet hook on the other side of the rops completes the picture.
/ Carrying stuff on your Kubota? #12
The only thing is it is kinda awkard to hook a chain on the hitch under it.
/ Carrying stuff on your Kubota? #13
I made this box out of some leftover cabinet plywood and a couple of square u-bolts (dont remember where I found them, think they came of a fork frame)that fit the ROPS exactly. I have 2 chainsaws, oil, fuel, chains, crowbar, machete, chains, brush puller, lopers, gloves and a small tool box in it right now, but i take it off when using the box blade cause it blocks the view.
/ Carrying stuff on your Kubota? #14
I glued the end caps on and painted. Drilled a hole for a nail to hold it in position. I cut the PVC to fit the length and cut part of the tube to make it easy to put the chain in and get out. A thicker PVC would be sturdier but I used what I had and it does ok.
/ Carrying stuff on your Kubota? #15
I use a modified TSC carry-all. It was cheap to buy and add on to. While it is effective I find I usually need my box blade on for a counter weight and to push logs and earth around. So, I think will do make something like Bigman has done.
This is a real nice set-up-
wilsonoutdoors.com - The Ultimate Tractor Carryall Project
/ Carrying stuff on your Kubota? #16
Excellent idea Chuckie.... I have been looking at those spaces on my Bota and wrestling with different ideas.... of all my ideas, I like yours the best... Creative thinking wins every time... Thank you.. :D
/ Carrying stuff on your Kubota? #17
I Had a sheet metal tray hat was used for some kinda guard t a factory where I work and they threw it out.
I mounted it to the cross bar behind the seat that connects the fenders together and use it for the small stuff like reese inserts, extra linch pins, clevis, gloves, tools, etc etc.
As for the water bottle I keep that in the cup holder:)
/ Carrying stuff on your Kubota? #19
I will be able to post pics in a few hours. I am not at home right now.
Two of them are done and being used daily and the other one is not 100% done yet. Just need to finish the sides and it will be ready.
/ Carrying stuff on your Kubota? #20
The First pic is before we painted them but they are the same trailers.
I have several pics of the build up on two of the trailers, I can post if someone would like but I don't want to hijack the thread.
BTW the smaller one is 4' x 8' with 2' sides and the larger one is 4' x 9' (just enough to get a fifth row) with 32" sides
2019 Nissan Maxima Sedan (A61574)
2019 Nissan Maxima...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
