Weight Issue
/ Weight Issue #1
Big Jon
Indianapolis, In
John Deere 4210
I am purchasing a used trailer (7000 GVW) for my JD 4210. I have all the specs for my tractor and toys except for the front end loader (JD 420) and the mid mount mower (60" 7 Iron commercial). Does anyone know the weight for these items?
Thanks for any help in advance!
Jon
/ Weight Issue #2
Just a guess but your trailer probably has about 5000 lb payload capacity. So I wouldn't want the tractor and implements to be more than that.
Steve
/ Weight Issue #3
Big Jon, thinking aout it more I would keep looking for a 10,000 lb trailer with a 18 to 20' floor. Just a little more money for a lot more trailer, and would last a long time. I have a 12,000 lb Big Tex 12PI to haul my 110 tlb on and have no regrets. There are few things more irritating than having to worry about an overloaded trailer.
Steve
/ Weight Issue
Steve,
I agree on the 10,000 lb but I found this 7,000lb for a song. That is why I am researching the weights... Tractor and BH at 3600 lbs. Haven't purchased yet still investigating. Thanks for the advice.
/ Weight Issue #5
I think my 12,000 lb trailer with ramps, brakes on both axles and spare tire was only $3100 brand new. You should be able to find a good used one for half of that I think.
Steve
/ Weight Issue #6
Steve, How long have you had that trailer?? I need to buy one for that price!!
Big Jon, I would GUESS the 60" mmm would be 380 lbs and 420 loader 1100 lbs. I have a 5000 lb trailer and it easily hauls my 4310 with 430 loader, 72" MMM and 655 rototiller. I think the 7000 lb trailer will work fine, just be careful.
/ Weight Issue #9
Big Jon, looks like everything is adding up to 5100 lbs or close to it. While I would want to get a higher capacity trailer you may be fine with the 7,000 lb. trailer. Does the registration paperwork for the trailer list its weight? How old is the trailer and what kind of condition is it in? What is the price being asked?
Steve
/ Weight Issue #10
mfreund, I bought my Big Tex 12PI 20' tandem trailer in Feb 2005 for $2995 + spare tire and wheel.
Steve
/ Weight Issue #11
Steve, That was a great price even 4 yrs ago!! I need a bigger one but I only use it 1-2 times a year for the tractor. Hard to justify to the CFO.
/ Weight Issue #12
Steve must be down south because you can't get a new 12K trailer with spare and brakes on both axles in the northeast for that price.
To the OP you will probably be right at the limit with a 7K trailer with the attachments mentioned. If the price is right go for it.
/ Weight Issue #13
I haven't checked 2009 prices to compare them. I live in New Mexico and the Big Tex trailers are built next door in Texas.
Steve
/ Weight Issue
Steve
Gentlemen,
Sorry so long in returning. Out of town for awhile. I found this older used trailer for $500. It is a little rough and some quick expense calculations, over time, of repair parts/ material brings this to a song for me and gives me another project to piddle with. I will not be using everyday so time is not important just knowing I will be mobile with the "Toys" gives me great satisfaction.
Lebrown
I am pulling it with a 1/2 ton pickup.
jenkinsph
The owner is looking for title it was registered last year. Did not think of that...Great advice will look into.
By my calculations I am estimating around 5600 for the "toys". So I will have to be careful not to overload. If I must I may have to make two trips if needed but I see that being rare.
/ Weight Issue #15
For $500 its well worth it even if you had to replace brakes, tires lights etc. You got a good buy for a 7K trailer.
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2003 Toro Workman 2110 Gas Utility Cart (A66734)
2003 Toro Workman...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
2017 Crane Carrier Co. T/A New Way 31ASL Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
20' Container (A64912)
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
