Tractor hours - why so low?
/ Tractor hours - why so low? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've been looking at a LOT of used tractors. When I finally plunk down my sweat rewards I'll probably be putting in the equivalent of a quarter years of work value to get that tractor.
I see all these tractors with less than 100 hours of use a year. That's only about 1 day a month
Example "purchased new in Feb, 2004. It has been garage kept and in excellent condition w/ less than 80 hours."
example 2 "I have a 4wd L3400HST, FEL, loaded r4's and Woods 60" rotary. I've had it a little less than 2 yrs (about 75 hrs on her), and have recently"
Is it that easy to turn back an hour meter? Do a lot of people buy new hour meters? Or are there that many guys that need the power but don't use it?
I'll probably put that many hours on in the first 6 months just digging holes and filling them back up.
/ Tractor hours - why so low? #2
My 1997 F935 now has 100 hours on it. When the hourmeter quit, I bought a new one from Graingers and now she's as good as new!:D
Look for new screws holding it in instead of pop rivets....
/ Tractor hours - why so low? #3
Some people have small acreage and simply don't rack up the hours. I just traded in a JD 790 that I bought new in June 2004. It was always stored inside and only had 168 hours without a dent or scratch on it.
For example, I mow a one acre lawn and only occasionally brush hog the other acre I own. I also use it to keep the driveway cleaned out in winter and for a little FEL work now and then.
/ Tractor hours - why so low? #4
Of course there is no "rule of thumb" when it comes to useage/hours...I'm sure you'll know the right one when it comes along...Personally, I average maybe 50+ hours a year on one...But then again, mine's not used for work to make a living.
Don
I can understand equipment expenses for standby requirements. A LOT of people should plunk down a grand or five for a generator that hopefully they will only use to make sure it runs.
But to drop $10K to $20K on a tractor and let it go unused seems a shame.
/ Tractor hours - why so low? #6
It is not really unusual to see them with hours like that if they have been a homeowner/small acreage tractor. I had a MF 1433v for 5 years. I traded it in last year with about 250 hrs on it. I had bigger tractors for the ranch work and this tractor just ran a post hole digger and mowed the yards. I traded it in for a 70 hp Montana that I could use to expand my haying operation. It is over 150 hrs now and I didn't get it until August last year. It should pick up a lot more hours next summer.:D
/ Tractor hours - why so low? #7
I tend to agree with you, Newbury- letting them go unused would be a shame. But a low number of hours doesn't necessarily mean they go unused. I bought my 2305 in 2007 and only have 43 hours on it. I have ~1.5 acres to mow each week through summer and the occasional snowfall to push out in winter. Sometimes I drag the bushhog around so I don't have to tramp through chest high weeds to get my dogs into a pond. Every once in a while I'll cut down a tree, or move some stone or mulch. In short, I get plenty of use out my machine without running up a lot of hours. Most of the work, other than mowing, I do at slower RPMs (so the meter doesn't run up so quickly), and it rarely takes very long. I've only got a few acres to play on and don't need the machine every day. But I get plenty of use out of it and I wouldn't trade it in on a cheaper model.
Most of the low hour ads you see are probably from people just like me. We want something big enough to do anything we can imagine, but don't need it every day. Unfortunately, that costs $10-20K... If I had something cheaper my back would be hurting a lot more!
/ Tractor hours - why so low? #8
I second that. Having a FEL eliminated a lot of work previously done by wheelbarrow. Even used the Payne's forks when building a 12'x16' deck by myself. Lifted and held a 16' pressure treated 2x10 in place so that I could level and screw it to the house.
I also used it to lift a 10'x12' loft into place until I could get some legs bolted to it in my steel building.
If you have the machine, you'll find ways to use it that you would never have thought of before.
/ Tractor hours - why so low? #9
I feel like I sometimes live on my 45hp Branson - from bush hogging parts of my 200 ac lot to moving dirt around to blowing snow up here in the Canadian winters. Still, I have only managed to rack up 190 hours in over 4 years. Must be the -20 deg snow blowing without a cab that makes those hours tick by oh so slowly!
/ Tractor hours - why so low? #10
To watch for on some older tractors the hourmeters roll back to zero at 1000 hours. Gary
/ Tractor hours - why so low? #11
I must be over working mine, I average a bit over 200 hours per year. I have a 2005 DK35 and it now has 840 hours on it.
/ Tractor hours - why so low? #12
Understanding the meaning of the hours indicated by those dashboard indicators can be tricky.
The hour meter on my 1964 MF-135 diesel is part of the mechanically-driven tachometer. It registers accumulated engine hours at an average 1875 engine rpm. I rarely run the engine as high as this. In fact, 540 rpm on the pto corresponds to 1700 rpm on the engine. So the actual engine running time (the wall clock time) can be considerably more that what's indicated on the hour meter.
The digital hour counter on my 2008 Mahindra 5525 operates electronically by pulses coming from the alternator. I would be surprised if that counter is smart enough to factor in engine rpm so that the indicator shows the actual wall clock time that the engine has accumulated.
and
I did not realize that "tractor time" could be like "women time" (as in "I'll be ready in a minute Honey")
/ Tractor hours - why so low? #14
We'll for us on our IH1066,
We purchased this in 1994 with a new Farm King 9600 snowblower, it had 150 hours on a major overhaul. We've mostly used this for snow removal, we have disked up the entire farm and reclaimed land, we have ditch bank mowed with it during the summer.
Last summer we cultivated the farm a bit and we cleaned out 100 years of junk and reclaimed a lot of land. But looking at my spreadsheet on the tractor we have only put 600 hours on this tractor.
Now take our NH T2220, I just got this one in December and have already put 21+ hours on it helping out with snow removal, the wife says I'm having too much fun with this one:D.
Now the 1066 was a one owner Farmer used tractor that was built in 1975, it was ninteen years old when it came to me with only 7305 hours on it. This tractor was used in the work of row crops only. So the farmers use on this tractor was only about 384 hours a year.
/ Tractor hours - why so low? #15
On the other hand here in farming country, it is not too unusual to see tractors for sale with 8,000 to 10,000 hours on them, and the owner still wants to get rich quick.
I bought a 3-4 year old used Farm Trac with less than 30 hours on it a few years ago.
I probably average 20-50 hours per year on it. Not used often, but real glad when I need it.
Yooper Dave
/ Tractor hours - why so low? #16
Age does not equal use.
just because you own a tractor doesn't mean you fire it up at 7am every morning and then shut it down at 5pm, 6 days a week.
I've bought antique tractors with OEM proofmeters .. these are 50 yr old tractors that litterally had 500+/- hours on them.. as evidenced by engine internals, and lack of wear / repair.
Other people use their tractors more and rack up the hours. Some of us put lots of hours on certain tractors.. and few on others.. IE.. people that mow like farmwithjunk, load up his mowers with lotsa hours as they are working tractors.
During the growing season, my mowers get weekly use.. while the rest of my 'toys' are lucky to see an hour a week... some less.
that's not to say a machine can't be scammed to look newer than it is... or just have replacement parts due to damage.. etc... My 1975 ford 5000 has obviously had a dash cluster replacement sometime inthe last 34 years.. not recent.. but not roo far back either.. use on her shows more than the 10 hours the meter does!
soundguy
/ Tractor hours - why so low? #17
and
Almost all(maybe all) newer tractors have electric tachs. The tach itself works only when the engine is running, but many will record hours anytime the key is on(running straight "clock" time). My newest MF runs the tach off of the alternator and my older 4243 runs off of a sensor on the hydraulic pump.
/ Tractor hours - why so low? #18
*Is it that easy to turn back an hour meter? Do a lot of people buy new hour meters? Or are there that many guys that need the power but don't use it?
I'll probably put that many hours on the tractor in the first 6 months just digging holes and filling them back up.
My hours are split between 3 tractors.
So naturally this results in lower than normal hours on each tractor.
I also have 3 pick ups and here again this has resulted in way lower than average milage on each truck.
*What would be the point in turning back the meter when the hours on the tractors are all ready so low?
/ Tractor hours - why so low? #19
It is very possible to find a tractor with low hours on it I know people with tractors similar to mine that don't put 50 hr's a year on, mine on the other hand I bought near the end of July with 180 hr's but had 350 hr's on it at the beginning of Dec., Haven't put many on over the winter just blowing my own driveway but with spring approaching hopefully the hr's start to rack up again as that equal's $'s. Took the blower off last week put the hoe on this week for one day's work had a bit of frost though and one day is enough till it thaws a little more. Gary
This forum is great, so many helpful responses.
Well I am relieved to know that the community here thinks these hours tend not to be scams.
Now I have to hope I'll find some homeowner that bought a TLB as a toy and now the significant other wants the cash back. I only need a small one (20-30hp) as a self learning tool, and anticipate moving up to a larger one in a year or two. But still I expect I (or one of my progeny) will put on at least 40 hours time in the first couple of months.
IF a tractor is kept for 10 years and costs $15K over it's final sale price then it costs $1,500 per year if it's used or not.
That's about like hiring someone with a tractor for 15 hours of work at $100/hour. Or buying 10 to 20 acres more land. But I need a TLB for the 400 I've got:)
You know you've got it bad when you evaluate everything in terms of one thing you want - I look at a weeks grocery bill as a quarter acre of land! Pretty soon I'll probably think of it as half a box-blade :)
UNUSED ATS EJ 11000 ELEC.JACK (A62131)
UNUSED ATS EJ...
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
(APPROX. 250) UNUSED IRANCH TRAFFIC CONES (A62131)
(APPROX. 250)...
JOHN DEERE 344H WHEEL LOADER (A63276)
JOHN DEERE 344H...
UNUSED SDLANCH 20' X 30' ALL-STEEL CARPORT (A62131)
UNUSED SDLANCH 20'...
2022 All Aluminum Timpte 514 Trailer Electric Tilt (A63118)
2022 All Aluminum...
