Please help. Homework. I'm Stuck
/ Please help. Homework. I'm Stuck #1
disoblige
I have a 55.3 Horsepower Engine and I have a 35400lbs load.
I will have to choose the pump , gearbox and drum. Can you help me?
Find Speed
Rule: Motor should only use 80% RPM
what should i do next?
/ Please help. Homework. I'm Stuck #3
It takes 53 HP to pump 26 GPM at 3000 psi, so if you run that engine at 2500 rpm. you will need a pump with 2.4 cu in.
You need to figure the gear box, to pull that load.
A hydraulic motor of 2.4 cu in, at 3000 psi, will have 1,146 in lbs.of torque , 2403 rpm motor speed at 100 %
/ Please help. Homework. I'm Stuck #4
Please let us know if J.J. gets an A
Wedge
26gpm and 3000 psi is not 53hp. it's 44.5 ?
/ Please help. Homework. I'm Stuck #7
That part was easy, the hard part is to figure out the gear ratio, and drum size, and cable size to winch 35,400 lbs. For instance, my electric Ramsey 9000, uses a 3/8 in cable, but it will only pulls 9000 lbs on the first layer on the drum.
How about telling us what it is you are trying to pull, and is it a rolling load or a static load. or is this just a test question.
You do know, that with the proper gear ratio, you can just about move anything. IE, torque multiplier.
can you give me a hand in the easy part. how did you get the displacement and the rpm?
/ Please help. Homework. I'm Stuck #9
(26 x 3000) / 1714= 45
/ Please help. Homework. I'm Stuck #12
I used the calculators in the hydraulics section. I assumed that was a diesel, running at about 2500 rpm. Some trial and error will find out what you want to know.
/ Please help. Homework. I'm Stuck #14
Don't forgot about efficiency. I think it has been said here that the pump efficiency is ~80%.
Chris
/ Please help. Homework. I'm Stuck #15
It appears that your formula is using an efficiency of 85 % according to the people that wrote the formula from the hydraulic site. So if that is true, then you lose some HP in the transfer of power. That means that you have 45 HP going to the pump using a 53 HP engine.
I believe this is correct, but if not, someone will correct it.
/ Please help. Homework. I'm Stuck #16
Chris
Chris, I believe the 80 % efficiency is the HP from hydraulic pump to hydraulic motor. The other figure is from gas engine HP to hydraulic pump HP.
I could be wrong, so double check .
I did some research what is the difference.
your site uses hp = psi x gpm x .0007
This equation means the engine is 85% effiecient and calculates what is the horsepower need for engine to run the pump.
hp= psi x gpm / 1714 x overall.eff of pump
This equation means at 100% efficient engine and finds the pump HP. This is what we used in school.
Required HP Calculator (two answer) . correct me if i am wrong. In conclusion your site using the more accurate equation.
/ Please help. Homework. I'm Stuck #18
Your 1714 number is for 100% efficiency, but don't forget the efficiency from hydraulic to hydraulic motor.
Use the Theoretical Hydraulic Calculator,.
Permco Hydraulic Calculator
My rough copy. I think i am missing something or i did it wrong? Also My pump Hp is off by .5. I do not know why.
Given: 55.3Hp engine and 35400lbs
Efficiency (I made up)
Pump: .94
Motor: .9
Gear:0.95
55.3 x .94 x .9 x.95 = 44.44 HP output
44.44hp x 33000
-------------------- = Speed (FT/MIN)
35 400lbs
=41.4314 feet per minute OR
=497.1769 in/min
Choosen Drum is 8 inch diameter
8in x 3.14 = 25.12in circumference
Finding RPM
497.1769 in/min
---------- = 19.79 rev/min
25.12
Chosen Gearbox 50:1 . Chosen motor 5 cu.in disp motor. (HUGE)
Finding Torque:
4in(radius of drum) x 35400lbs
--------------------------- = 2981.1526 in lbs
50 (0.95)
Finding pressure:
2981.1526 x 2 x 3.14
--------------------- = 4160.3640psi
5cu.in x .90 (eff)
Finding flow :
19.79rev/min x 5cu.in x 47.5
----------------------------- = 20.3468gpm
231
Finding out HP of pump (checking):
4160.3640psi x 20.3468gpm
---------------- = 52.5352
1714 x .94
He want us to pull a egyptian pyramid using our last 3 student number x 1000lbs and gave us a sand co-effiecient friction of 0.6. He wants all the calculations.
2000 Freightliner Classic XL T/A Sleeper Cab Truck Tractor (A66736)
2000 Freightliner...
Connibear Hotshot Applicator (A64912)
Connibear Hotshot...
2020 Honda Rancher 4X4 ATV (A66738)
2020 Honda Rancher...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2024 Chevrolet Camaro Coupe (A66738)
2024 Chevrolet...
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67737)
2012 INTERNATIONAL...
