BX24 wont turn off!
   / BX24 wont turn off! #1
SEB
newfoundland
BX24
My BX24 ran well today blowing about 12 driveways w/ 10 inches of slush . . . problem was that the machine would not stop running even after the key was placed in the off position then removed. Not even the PTO kill switch in the seat would do it.
I came inside and looked up this forum to find what was going on and saw a number of links to solenoid and fuse issues - so I went back out to the tractor to introduce myself to the solenoid and fuses - found that it had shut down during my absence.
After poking around for a bit I discovered that my problem was actually that the battery cable had wiggled off the battery post and contact had been lost. I replaced the cable tightened it up and the machine started and turned off normally. Problem solved.
I would not have guessed that the machine would behave this way with the battery disconnected - perhaps it was just a strange coincidence of timing, anyway - I thought I'd add this scenario to the books.
Cheers, Steve Bruneau
   / BX24 wont turn off! #2
Diesels once running do not need any power to keep running, unlike gas engines. I suppose with no battery power, it didn't have any way to turn off the fuel.
   / BX24 wont turn off! #3
Diesels running do not need any power to keep running, unlike gas engines. I suppose with no battery power, it didn't have any way to turn off the fuel.
Um, except the electric fuel pump. That's why it finally died.
   / BX24 wont turn off! #4
This is where a shut off valve comes in handy .
Makes changing fuel filters less messy too.
2015 Chevrolet Equinox SUV (A50324)
2015 Chevrolet...
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
71066 (A49346)
71066 (A49346)
2014 GMC Sierra Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2023 JOHN DEERE 50G EXCAVATOR (A51242)
2023 JOHN DEERE...
