Electric fencing question
/ Electric fencing question #1
netwayne
Tar Heels Baby!
I am a newbie to electric fencing. We recently attached about 1200ft of wire or braided to the top rail of our wood fencing using a Solar charger from Southern States that is rated for 20 or 25 miles. Charger is fully charged and grounded to a 6.5 ft buried galvanized ground rod. After making all the connections, we turned it on and tested it with one of those cheapie test lights which showed current passing through all areas of the fence. But of course I wanted to know, if it's REALLY working so I grabbed the wire and barely felt anything but did feel the pulsing. Outside of me going barefoot in a wet area and then touching the fence...:p, what is the best way to test to make sure it is up to snuff? I see there are digital voltmeters for electric fencing and some just provide a digital readout for volts and others include some short or fault information. What's recommended?
/ Electric fencing question #2
You may have had good shoes on and got lucky. I like to take a wood handle hammer and hold part of the head against a steel post and hold a gap about 1/4" to 1/8" away from the wire. You should get a blue/white spark with a loud pop. Make sure your ground rod is very deep and in moist soil. Use insulators for the wire or tape you are using. You can't attach right to the post even if it's wood.
I have used one of the multi light testers you talked about but a hammer tells me more.
Dan
/ Electric fencing question #3
When you say you attached the wire to the top of the wooden posts, you did use insulators right?
I have one of those digital meters, it gives the voltage readout, the amount of currant passing through as well as the direction (left or right) to any short.
My charger is rated to 100 kilometers, and its energising about 3 miles of gal wire, and about 600ft of poly braid.
I would be lost without the digital tester.
/ Electric fencing question #4
You might want to re-check your line. The wire might be touching wood, etc., along the way and that would explain why your not getting much shock.
Of course, if you're wearing rubber boots you won't feel much. Where were you standing in relation to the charger?
The light meter I have has five lights, and the stronger the pulse the more lights flash. Got 5 lights going off anywhere I touch. How does yours work?
Also could be your ground. Loose/tight connection? I've got three 5' rods buried three feet apart. I think most chargers recommend more than one grounding rod.
/ Electric fencing question #5
Also many new work books have the EH rating for electrical. One guys up here held a spark plug wire and turned the motor over on a lawnmower and didn't feel it. Needless to say he's braver than me for testing it, but it worked for him so the insulation may be your cause. I would check to make sure you have a good ground and that it's not grounded out elsewhere like the others have mentioned.
Thanks all for your replies!
Here's some answers to questions I saw in your replies.
Yeah, now that I think of it, I was wearing rubber mucking boots so I guess I was pretty well protected.
I was within 10 feet of the solar charger (6 volt) when I was "testing" the wire.
Yes, I am using insulators for both the wire connections to the wood post and also the braided wire. My tester is a cheapie...just a single light that illuminates when current is passing. To test I just touch the wire after I stick a probe into the ground.
It's currently a single ground rod system which is what was suggested by the mfg'r but they did say depending on the situation I could add more ground rods. I figured I would just start out with one (it's buried about 6 1/2 feet) and my system is relatively small (1200 feet of fencing).
Curious about the actual ground rod connection to the charger. The ground wire itself is fairly thick and not easily wound around the connectors on the charger so I had used an aluminum connector to join that thick ground wire to a short piece of the thin wire used in this project which easily went around the wire connection on the charger. Is that what you all do for this connection? And those that mentioned fence testers...what make/model are they?
Thanks again!
/ Electric fencing question #7
I don't have the solar one...all electric.
On mine the manual said to use 3 ground rods...but I'm only using two and get good power on the fence.
Something i did and later found in the manual...was to put my ground rod where the ground is damp...seem like that really boost the power up.
You would want to check the insulators to make sure that they aren't arcing off a nail...or your wire isn't touching a post.
I have a tester, and another thing that i fixed up to test with, was take one of those insulator gate handles and run a wire from the fence to the handle...and hold it down to touch the grass and i can see the blue arc and hear the pop....(and all the worms come to the top of the ground:D)
It might be best to check to see if the ground is damp at the ground rods...if not, you could wet it down and then check.
/ Electric fencing question #8
My guess is that the rubber boots saved you from an unforgettable experience. If you want to test your fence again by grabbing hold of it, please wear sandals and have a friend take video. :)
I used crimp on terminals to connect the wire to the charger and they seem to work just fine. I have one of those 5 light (diodes) testers from TSC and to be honest, it's not very good. It's almost impossible to see the lights during the day. I have to check it at dusk when they are a little more visible.
If you've got your grounding rod 6' in the ground, that should be more than enough, if the ground is damp. I used two 3' rods because it was impossible to drive one rod that deep.
/ Electric fencing question #9
I almost hate to tell on him, but my FIL had a similar expereience with his little solar fence charger - he would gingerly touch the fence, and then when he felt little or no shock, he got mad at the charger (and the retailer he bought it from) assuming that it wasn't functioning. We (me and both of his sons) tried to tell him that without grounding himself first, he wouldn't/shouldn't really be able to feel much. He did not believe us. So we just silently watched as he took off his boots and socks and tried it again.
He has not "tested" the fence again in the several years since!
- Jay
(Sorry to say that no one got any video of "the test" - it probably would have been a contender on "America's Funniest")
/ Electric fencing question #10
I use an $11 tester that I got from TSC (Fence Tester), and it has multiple lights to indicate the strength of the charge. I've never felt compelled to personally verify its accuracy. :D
Or you could just hire these guys: Brainiacs
Pretty funny ending to the brainiac segment....I had forgotten to mention in my original post that the first time I grabbed the wire, I did my best "Green Mile" impersonation of the guy's reaction sitting in "old smokie". I have to say though that I could save myself some money on the fence tester by just hitting that wire barefoot!! :D
/ Electric fencing question #13
Did you say what you were keeping in or out and I missed it? Anyway, I plan to run both a hot and ground wire on top of my fence to discourage climbing beasties, such as coons. The fence fabric will be grounded, but I want to make sure whatever touches the hot gets zapped.
Chuck
Chuck
I don't think I did. 2 "filthy animals" of the equine variety and we are definitely trying to keep them in!
/ Electric fencing question #17
I dropped something by my electric fence, bent over to pick it up and on the way up, hit the back of my head on the wire. :eek:
I don't remember feeling anything. If fact, I don't remember anything until my wife woke me up and asked why I was sleeping on the ground. I haven't even gotten close to my fence since then.
/ Electric fencing question #18
ground ground ground. The trick with ground rods is to have them horizontaly seperated the same distance as they are verticle makes a differnce. I have a tester fro earth ground requierments. Most fail until we cad weld the connections and beef up the erath ground. Easiest way to drive a ground rod is to add water to the hole. Beat it then add water reduces friction. Worked on one site video uplink we had to drill a well and place a copper pipe in the casing to get a suitable ground.
Easiest way to test fence is to smack it with the back of your hand and say ouch. Your hand will not spasim and hang on to the wire. Now the level of ouch is differnt for differnt people!!!!!!
/ Electric fencing question #19
I have a Gallagher 5 light tester similar to what has been mentioned here. If I touch my fence with rubber boots on the shock is very mild, hardly worse than when you rub your feet on a carpet. BUT, a few times (YES, more than once everybody!) I have accidentially touched the fence when grounded and YIKES it really snaps hard. I think your fence is probably OK. If it's arcing at an insulator you should hear a snapping sound.
Ground rods are cheap, throw another one in for the heck of it. We use 3x 10 foot rods for our fence (electric not solar).
Funny stupid JimmyJ zapped real bad stories.
1. Fixing fence with "croc" shoes on in the morning dew. Kneeled down, touched fence ZAP!
2. Putting a tin roof on a shed that has electric fence running beside it. Cutting off excess tin sheet, sheet "hangs" down over edge of shed, touches fence, me kneeling on tin roof - ZAP!
3. I have an aviary with 6 foot high wire fencing around it. At the top about 2 inches outside the wire I ran a hot fence wire to discourage climbing coons and so on. Well, peeking inside at my birds one day while leaning on the wire fence, by bald head touched the hot wire! ZAPPO! That one was really nasty.
LOL I'm still alive but not so bright I guess.
/ Electric fencing question #20
I accidently tested an electric fence once. It was before I learned the concept of alternating hot/ground wires along a fence.
I brushed against one strand of a marked fence and since I got no shock grabbed two strands in order to seperate them and go through.
I swear I heard the strobe of current go through me a tad before I felt it. Now I make it a point to stay away from electric fences. ;o}
