tow ball....small shank....where?
/ tow ball....small shank....where? #1
diesel_nut
Gold Member
Tennessee
~'88 1872(sold); '08 GT2554
Where do you find a tow ball with a small enough sahnk to fit in that small hole on the new lawn tractors?
Need a 2" ball.
/ tow ball....small shank....where? #2
Most 2" trailer balls need 1" hole,and guessing the hole on lawn tractor 1/2"....milling down size to fit lawn tractor hole might affect 2"ball safety...can you drill out lawn tractor trailer ball plate.?
/ tow ball....small shank....where? #3
I took a cheep one and cut off the stud and tapped ball 1/2-13 its OK for light duty.
Given the sheet metal on lawn tractor you probably wont break a grade 5 bolt off before metal bends.
tom
/ tow ball....small shank....where? #4
Build a bracket off from the frame is what my dealer told me when I asked about the stamped steel plate and how well it would hold up.
/ tow ball....small shank....where? #5
Take the ball into the dealer and ask for a tractor that fits it.
/ tow ball....small shank....where? #6
Need a 2" ball.
Pretty much every trailer ball has a 1" shank (6000#+ rating) or a 3/4" shank (3500# rating) I haven't seen much of anything smaller than that.
as has been said, try making a mount with the size hole you need.
Aaron Z
/ tow ball....small shank....where? #8
You aren't likely to find a 2" ball with a shank smaller than 1". If they were available, they would probably cost less than a ball with a properly sized and strength rated shank, and a significant group of morons would buy them and use them to haul 5000lb trailers up and down the highway. Which would be an exceedingly bad idea.
/ tow ball....small shank....where? #9
TSC has 1 7/8" ball with 5/8" shank. For a larger ball you have to cut off shank and drill and tap for the size you need.
You could go this route: Hitch Receiver
I like that because it retains a pin slot for a small wagon that you usually use on lawn tractors without having to remove the ball to us it. That is SLICK!
/ tow ball....small shank....where? #13
I have one of those on my 2542 CC. I plan to clone it and put one on the 1250 and 1000.
/ tow ball....small shank....where? #14
If you have an old tow ball I believe they are threaded into the ball, remove and use a bushing. I havent tried this, my light weight equipment has pins.
/ tow ball....small shank....where? #15
Hey folks, we're talking lawn tractor. Probably will never tow 10K. Drill the hole bigger !!! MikeD74T
Mike the only problem I have with doing that is the fact there is a flange built into the mounting area and you'd lose that and some support for the thin metal present there.
/ tow ball....small shank....where? #17
Then maybe this tractor isn't suitable for towing anything that needs a 2" ball ???? :confused: MikeD74T
I have a small mesh-bed utility trailer I want to move from part of the yard to another and it has a 2" receiver. I can push it by myself as it is that light but quite the pain. I could hook it up to my diesel truck but quite often this time of year the yard is very soft. I'm not wanting to pull anything heavy. It is just for convenience.
Golly Mike you mean it won't pull my 32ft toyhauler.....................
biting my lip at this point
/ tow ball....small shank....where? #19
diesel nut, I appologize for seemingly dissing your tractor, not my intent. I wasn't aware that newer lawn tractors are so lightly built that one couldn't increase a 1/2" hole to 3/4" without loss of integrity. Your intended use is what I would have expected. MikeD74T
Top and bottom of mounting area. If you drill it out you will lose what structural strength is there from that flange and all the pulling force will be born on relatively thin metal. Hope this helps make my point about drilling it out.
Of course you could drill and use washers on either side and hope it gets tight enough that the force is on the washers and not the mount area. But sooner or later the pulling on it will get to the mount.
Pretty darn good pics for a cell phone camera!!
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
2017 Buick Encore Preferred SUV (A61574)
2017 Buick Encore...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2010 Acura MDX AWD SUV (A61574)
2010 Acura MDX AWD...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
