2210 water pump change
/ 2210 water pump change #1
edjones72
Member
South Georgia
Yanmar YM2210, Cub Cadet 2166, JD2940, Mustang 440 skidsteer
Had a less than ideal day tilling on Thursday when my water pump seized. Got another one on the way and the old one already removed. Can someone tell me the torque specifications for the mounting bolts? Hopefully I'll be up and running by mid week. Thanks!!!
Eric
That is a good reference chart but it says not to use these values for gasket joints which is what I'm dealing with.
Eric
/ 2210 water pump change #4
Eric,I have a 1610d and the closest Manual ,the 226d.It gives as far as I see no specific torque setting when putting the pump on.I just received a new one today and as soon as I get the head out of the machineshop next week I will instill it .If anyone knows of a specific torque setting I'd like to hear also.
/ 2210 water pump change #5
I always tighten the first bolt until it either breaks or strips, note the torque that was required and reduce by 15% on the rest. :rolleyes:
I doubt there is a torque spec on the water pump bolts as it is a gasket joint. When I did mine I used a 1/4 ratchet and socket and tightened to what my calibrated arm called tight enough. Maybe one of the dealer types has a more specific suggestion? :confused:
/ 2210 water pump change #6
BadMojo, bout what I was going to do anyway ,last part of your note anyway. More curious about any torque specific listing than anything.
