John deere 4x2 gator
/ John deere 4x2 gator #1
cat2
is there anyway to get more power or speed from it? or both? :confused:
Thanks!
4x2 has the gas
/ John deere 4x2 gator #4
well their is not much you can do to get more power out of it
but you could try and find a high paformic carb for it somewere
/ John deere 4x2 gator #5
There is no quick and easy solution and you want to be careful about making something with no rear suspension go fast. I have a kite string on the govenor lever that comes off the engine and run it up under through the parking brake slot. You can give that a yank in times of need. This however is not recomended for full time speed. Your engine will not last too long. I too have had your problems and feel your pain. I'd love and XUV but am stuck with my 4x2. It is 4 miles from one side of the farm to the other and its a long ride if you have to do it in one shot. The 4x2 is built to last not for speed unfortunetly.
Anyone have any ideas where i could buy one?
Yeah thats not too good, because your over reving the engine. I don't think i would do it. But ya never know :rolleyes:
/ John deere 4x2 gator #8
The Green Dealer sells clutch kits that gain 3 MPH, but at a high cost. I have thought about it for my turf model...but have not researched it enough yet.
isn't that just for the ones that go 15mph so that would take it up to the normal 18
/ John deere 4x2 gator #10
Yes, I thought the "normal" was 15 MPH, but I am not a gator expert by any means...I have only had my turf model for a few months...and have not really gotten into the inner workings of it yet. There is very little info on the net about mods though it seems.
/ John deere 4x2 gator #11
The problem with changing the clutches is that you still have an under powered engine. As for a performance carb's. assuming that you go with a motorcycle carb it will be tought to maintain a constant speed with a gas pedal and also you run the risk on over reving the engine with out the governor. Over reving can cause the ACR to come apart on the cam also. Just for the record I only use my string when the engine is under load.
Kenny, don't quote me on this but I think the 4x2 turf is suposed to be a 15 mph clutch. Early standard 4x2's were 15 mph and somewhere in between got bumped up to 18mph.
FLAT BED (A65643)
FLAT BED (A65643)
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
20' One-Trip Shipping Container (A66285)
20' One-Trip...
25in Wagon Wheel Chair (A65583)
25in Wagon Wheel...
Danuser SM40 Skid Steer Pile Hammer (A65640)
Danuser SM40 Skid...
6ft Teakwood Cowboy (A65583)
6ft Teakwood...
