Oil & Fuel Oil change results
   / Oil change results #1
prophet455
Member
Just finished the complete 50 hour oil change on the m7040. A ton of material in the hydraulic oil. I am hearing that is typical for the first oil change. If it was engine oil on a car I would swear the bearings were gone, the oil was shimmering silver. Is this really the norm?
   / Oil change results #2
Yep, that's normal. I just did the 50hr change on a new B series and it looked like black metallic automotive paint with metal flake in it.
   / Oil change results #3
It was not what I experienced when I did the 50 hour service on my MX5000.
The hydraulic oil looked like it was new. Have you asked your dealer to look at it?
   / Oil change results #4
When I did the 50 hour on my B3030 I couldn't tell the difference between the new and the old hydraulic oil, nothing left in the bucket when I poured it off either.
   / Oil change results #5
I just performed the 1st full hydraulic service on my GL 3540, 170 hours. The hydro oil was clean and clear, there was however, a lot of metal bits on the magnet, in the base of the filter (break in material).
   / Oil change results #7
Same here.......when I did my 50hr service on my B3030 in October 08, the old HDT was just as clean as the SUDT I put in it.
Swmpbgy1
   / Oil change results #8
Same with my B3030. So clear it made me wonder if it really needed to be done at 50 hrs.
   / Oil change results #9
I changed mine at 300 hours, looked clear & clean as drinking water!
   / Oil change results #10
When I did the 50 hour service on my BX23, there was no metalic debris to speak of. I let the oil settle and when I poured it out of the drain pan, there was almost no metal flecks in the bottom of the drain pan.
I will be doing the 300 hour service this weekend and will report back on how it looks this time.
I would be worried if the oil came out looking metalic. That metal has to be coming from somewhere... more than just break-in.
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
2022 Horizon Trailer (A55973)
2022 Horizon...
