power beyond 2320
/ power beyond 2320 #1
sal64
ny orange county
jd 2320 jd 990 jd950
hello im new to tis website i have a jd 2320 with power beyond .i have a old 12 ton gas log spliter the gas engine is about to die can i run it with the 2320 power beyond tuvm sal.
/ power beyond 2320 #2
Welcome to TBN Sal :D
Yes, you can do exactly what you asked...but be prepared for the splitter to be much slower, since you will have only 3.4 GPM of flow to operate it. Also be sure to flush those hose and that cylinder thoroughly to get the old fluid out.
/ power beyond 2320
tuvm kenyd i have a 990 tractor maby im better off running the spliter with that tractor also what is the best way to flush the cylinders ? thanks sal
/ power beyond 2320 #4
The 990 would definitely be a better choice...
As for flushing, remove all the hoses and hang to drain, the manually cycle the cylinder to push out the old fluid. If it's super nasty the flush with diesel fuel.
/ power beyond 2320
hello getting ready to hook up my log spliter to my power beyond on my jd 990 do i hook the out of tractor femail quick coupler to in on log spliter spool then out log spliter to in tractor with mail quick coupler ? is it that easy.also can i put a filter on the out of spliter ?tuvm sal
/ power beyond 2320 #6
Yes, it IS that easy;)...
Just clean everything out like I posted before...and don't worry about the filter. The fluid will be filtered by the tractors filters. Also, after cycling the logsplitter a few times...recheck the fluid level of the tractor with the logsplitter retracted.
/ power beyond 2320 #8
Yes, you would be amazed at how much fluid a cylinder will drink the first time filled.
2017 Peterbilt 320 New Way Side Loader Garbage Truck (A66736)
2017 Peterbilt 320...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A69167)
2005...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2011 John Deere 1200H Bunker Rake (A66734)
2011 John Deere...
2003 Ford Mustang Coupe (A66738)
2003 Ford Mustang...
