Help with a plow?
/ Help with a plow? #1
henerythe8th
Member
SE MO
TYM 474 -- SS w/TX47 FEL Previously owned: Mahindra 2615, Kubota B7100D, BCS 737, Grasshopper Diesel
I was recently given this plow:
I helped my neighbor guy go and fetch a Case VA tractor and this came with it, he did not want/need it.
I think that I could use it, if I can figure out how to properly mount it.
It has pins for the lower links but it's been a bit jury rigged, I think.
Rather than having a regular top link mount there is a rod with two springs, and a sleeve in between. On the sleeve is an 'eye'.
I have a Mahindra tractor with a Cat1 3pt and I'd like to use this plow to do the initial work on about 4 acres of pasture that needs to be started over. I'd like to plow it all up and then till it prior to dragging, rolling and planting.
Anyone recognize the brand? I can find no 'tags' etc.
I'd appreciate any help.
/ Help with a plow?
Not even one single opinion, come on now...
/ Help with a plow? #3
sorry , couldnt be more of a help, I never seen that kind of a plow.:(
/ Help with a plow? #4
Good Mornin Henry,
Give it a day or two, my friend Farmwithjunk will see your post, and Im sure he can help you out ! He is quite knowledgeable about plows and most implements in general ! ;)
/ Help with a plow? #5
All I can say is...YOU LUCKY DEVIL!:)
There are lots or very resourceful folks here on TBN so I'm sure you will get good advise. I wold say to study pictures of TPH plows to see how they are attached. You may have to fab up a mount for the top link but that won't be difficult.
/ Help with a plow? #7
looks almost like a ford or dearborn but i never have seen that hookup
sorry not much help
/ Help with a plow? #8
Might help with a few more photos :D Different angles and what not...
/ Help with a plow? #9
The plow has been used recently.
From what can be seen the previous owner has kept part of the hitch up to the tractor system. Perhaps it was a custom type frame that also had other uses for him.:confused:
The threaded rod sleeve eye looks like it needs something solid to fasten to so it can be used to adjust the level and then you need something for the middle link on the three point to attach to. The springs may have given a Little flex if something solid was hit.:confused:
It also looks like it did have coulters at one time.
Be prepared for a bumpy ride when you are smoothing down the freshly ploughed pasture:D
/ Help with a plow?
Okay, so I was messing with the plow today and made some changes but still don't have the toplink mount figured out, yet.
I went and looked at the tractor/hitch setup that came on the Case VA that this plow was used with, what a mess, but I guess that it worked and that's what's important sometimes.
Here is a photo attached to my tractor, with the lower links attached.
I removed the pins from the large holes below them, the nuts were turned into the holes, it's amazing that the pins didn't pull through!
Part of this has been cut off with a torch just above the lower link mounts.
Here is a photo of the spring "top link" piece:
This piece that looks like a modified top link mount was part of the hitch system off the Case VA...
It was actually semi-horizontal and I guess that the sprung 'top link' was attached to it.
Any ideas?
Recommendations?
/ Help with a plow? #11
That piece that you see what was missing before. All the attachment points are there for the bottom links, top link and the threaded rod with the springs on it. :D
/ Help with a plow?
I was pretty excited, when I went and retrieved that piece off the Case, but when I got it home and to the plow...:(
...well that was a different story. It is NOT part of this plow, yet... ;)
What you see as lower link attachment points were welded to that top link frame for the 'home brew' hitch system on that old Case.
The frame is wider than the plow frame.
Another question that I have regarding a plow of this sort:
Is it normal for it to be so far behind the tractor?
I'd guess (I haven't put the tape to it yet) that from the lower link pins to the back of the gauge wheel (I don't know if that's what it's really called) that it's about 6.5 feet long!
/ Help with a plow?
/ Help with a plow? #14
After doing some more research/Googling, I am thinking that this plow started out looking a lot more like this...
http://www.frontierherbs.com/forsale/1a.jpg
I think your right....that well could be a semi-mounted plow. At one time Ford and Massey were the only ones with the 3 Point hitch and implements. So, allot of semi-mounted, 2 point hitch (allis) and pull type implements were prevalent on other brands. I dont think that plow started out in life as a mounted plow.
/ Help with a plow? #15
Good Afternoon Henry,
Im kind of suprised that Farmwithjunk hasnt jumped in on this thread, but for what its worth, Im including a picture of an old Dearborn plow that I refurbed a couple years back mounted on my Massey 3pt hitch. Obviously its a different plow but maybe it will give you some ideas ! :)
/ Help with a plow?
Hey Scotty,
Thanks for the photos!
Dang, that plows almost too pretty to use now, isn't it?
Did you modify that plow? Or is the design original?
/ Help with a plow? #17
/ Help with a plow? #18
I'm betting that your plow is an International "Little Genius" without the wheels and mechanical lift clutch. I believe the tailwheel/furrow wheel gives it away as its almost certainly an IH wheel. One thing I don't understand is that the Little Genius plows normally came with "Plow Chief" points rather than the one piece shares on yours. Good luck with it! BobG in VA
/ Help with a plow? #19
That's a Case plow, sold to fit VAC's. ('40's model) There's a couple on our local Craigslist now. (One for $100, better one for $225) The VAC that plow was meant to fit didn't have 3-point.... It was a mounted plow, but not the "mounted" most are used to. You almost need to see one in person to get the entire picture of how it worked.
OK....Making a 3-point plow outta one that isn't....: Not THAT difficult if you understand plow geometry. Plow needs to sit dead level when in operating position. (one wheel in a furrow, plow 7" or 8" "in the ground") Center of DRAFT LINE needs to run centered on tractor. Wheels of tractor need to sit just in plow furrow and equal distance fron centerline on opposite side. SOME adjustment will be possible with tractor's linkage, but for the most part, the plow needs to be properly oriented to the tractor from the start. Then you build a SOLID 3-point hitch "triangle" .
Still interested?
Oh yeah....Howdy Scotty!
/ Help with a plow?
I am interested!
As I work my way through this, I'll likely have more questions...
...thanks for sharing your expertise!
