Snowblower Meteor rear PTO snowblower
/ Meteor rear PTO snowblower #1
a1b8z
Comments, good or bad on this brand of snowblower appreciated. I bought one and have yet to use it.It is mounted on my Kubota bx2200 the model is sb51ec,actually mfg.by M.K.Martin in Elmira,Ontario. How does one know if you are running at the correct 540 R.P.M.. It looks very crude. Thanks!
/ Meteor rear PTO snowblower #2
i've sold Meteor brand blowers for several years as a lower cost option for some of my customers and they have worked out very well. Most of the ones we sold have had the optional skid shoes. Good Luck! Tractorman
/ Meteor rear PTO snowblower #3
I have had a 75" Meteor blower since '98. It works very well. I live east of Buffalo, NY. The (optional) skid shoes are a big help on my gravel drive, although they reduce the effectiveness of the blower on minor snowfalls.
I have found the weakest part of my blower to be the unshielded chain drive for the auger. I got a rock in between the chain and auger sprocket last year, and spent about $100 in parts replacing the chain, auger sprocket, and chain drive bearing. Other than that I have had no problems with it.
I generally switch to a rear blade late in the season, after Lake Erie freezes and the lake effect snow stops, because the blower is not that great for ice, slush, or less than 3 inches of snow.
/ Meteor rear PTO snowblower #4
I used my new 60" Meteor for the second time yesterday. So far so good. I have a 350' gravel driveway plus the turn-arounds, etc. The chute rotation is a bit crude but it does work fine. I'll use the additional skid shoes until I get a good base then I'll try removing them. One thing I am going to purchase is some kind face protection, ouch.
P.C.
Meredith NH
/ Meteor rear PTO snowblower #5
Can someone post a picture and some dimensions of the skid shoes, so I can see if my welding buddy can make me a set. I have had a 78" Meteor blower for a couple of years and I am well pleased with its performance. Simple, rugged design that does the job - it is hard to beat that combination, but I would really like to remove less gravel from my laneway when I use it.
Thanks
Bob
/ Meteor rear PTO snowblower #6
How much are they charging you to just purchase them from your dealer? Mine were $50 total and I doubt my welding buddy could make them for $25 ea. They do work well.
/ Meteor rear PTO snowblower #7
Thanks - I got mine second hand (a long story about and not necessary here) and there were no skids with it - I didn't even know they existed. I check with some local folks when I have a chance but, if anyone can post a photo I'd really like to see what I will be asking about.
/ Meteor rear PTO snowblower #8
I have a 60" Meteor rear PTO blower on my B2910. I clear 3/10 mile of relativily straight, hilly, gravel drive as well as my door yard. This spring in N central NH we had a few heavy, wet snow falls. The blower walked right through it. I keep the skids at their max until the snow packs then use them at the minimum untill the thaw in the spring.
David
/ Meteor rear PTO snowblower #9
Dourobob,Here is a picture of the skids on my Meteor. As you can see they adjust by moving to the next hole. If you have access to a welder and some metal, they should be easy to make.David
/ Meteor rear PTO snowblower #10
Excellent David - just like the rest of the snowblower - simple and effective. Thanks for the photo. I think this may be what I try when I take welding instructions from my friend .
Bob
/ Meteor rear PTO snowblower #11
Wow, a green meteor. Mine's bright red.
/ Meteor rear PTO snowblower #12
Gee, I didn't even notice the colour - being "colour perception challenged" as I am /w3tcompact/icons/grin.gif - the politically correct wording for "colourblind" I am told.
I figure that the skid I try to make will likely be black and mottled based on my lack of welding skills.
Bob
/ Meteor rear PTO snowblower #13
dourobob
Hey don't be so hard on yourself (at least before you try). Welding steel is not that difficult! Just play with a few pieces of junk metal first to get the hang of it. One of the biggest issues to newbe welders to remember: use clean metal. Don't try to weld through rust or paint. I will bet that in about 2 hours, you will have figured it out and will be more than ready to make those skids. Actually, if the pieces are already in the right shape(s), you could have them all set in 1 hour. Really!!! /w3tcompact/icons/grin.gif
/ Meteor rear PTO snowblower #14
Thanks for the encouragement. I am guessing welding is yet another one of those skills that looks and sounds much more complicated than it needs to be. MY buddy with the shop says he has lots of patience and lots of scrap so, hopefully in the next week or two, I'll give it a shot.
Cheers
/ Meteor rear PTO snowblower #15
BX 1850 with a 54" Meteor on the back. Not much snow in this picture, but the unit works well in deep snow. Skid shoes are a big help. Should get chains for the rear Kubota tires though.
/ Meteor rear PTO snowblower #16
I just got off my Kubota 4400 using the Meteor Blower. I keep open a road nearly a mile long to our Sugarhouse. Works just great, never have had a problem, I surely would buy another one.
Norm
/ Meteor rear PTO snowblower #17
I am on my second Winter of heavy snows using a 60" rear Meteor snowblower. It works very well. They tell me that these blowers are hard to come by this year. No too big of a surprise I would say. I'm sure glad to have this thing this year.
rim
/ Meteor rear PTO snowblower #18
Mine has worked very well for the last 3 years. I could have paid a lot more but I don't think I'd have any better results.
/ Meteor rear PTO snowblower #19
I see all you guys here talking about you PTO Blowers. Anybody here looking to buy one??? I am trying to help my uncle out, He purchased a 50 inch Meteor PTO Snow Blower Last year thinking he could use it for his Business. Well In the long run it was not practicle. The Blower has never been mounted on a tractor and was purchased new. I am not sure as to where you other Blower fans are from but we are in the central part of New Jersey. Here is a link for the Blower, it is currently on craigslist. 3 Piont PTO Snowblower if anybody is intrested, email me, message me, tie a note on a rock? Thanks for Helping.
