R1s or R4s?
/ R1s or R4s? #1
rpraymond
Madison Co., central NY
Kubota L3430HSTC, Kubota B2320 w/FEL, Allis-Chalmers D10
I'm looking at a B2320 w/ FEL. Primary duties would be to maintain a gravel driveway in the spring, summer, fall, and haul wood in the winter. All of my previous tractors have had R1s but I'm wondering if R4s would work better for the driveway and still offer the traction needed for winter work. Thanks to all.
/ R1s or R4s? #2
Now thats going to be the 64,000 dollar question.
/ R1s or R4s? #3
R1s hands down choice for me.
/ R1s or R4s? #4
.. No.
/ R1s or R4s? #5
I would not consider R-4's for those uses, if I had a choice. That said, if I were looking at a used tractor with R-4's, they probably would not be a dealbreaker.
/ R1s or R4s? #6
I would tend to lean towards R-1s. Not as gentle on turf, sounds like its not an issue though, but max traction in snow, dirt. My 2 cents worth....
/ R1s or R4s? #8
R4s for me...but my uses and needs are not the same as yours...:)
/ R1s or R4s? #9
OK!,I now like r4's,[cause thats whats on my tractor],but seriously,believe I do like them,best of both worlds would be r4's with a set of good chains.
To many people put to much air in them I think,is one reason some don't like them. But they have their advantages over r1's in many applications,and if you put a set of chains on them,ice won't stop you[r1's won't even go in ice].
/ R1s or R4s? #10
Once you start putting chains on youre talking chains...not tires.
/ R1s or R4s? #13
Sometimes I wish I would have gone with R1's instead of the R4's on my 790.
I don't use it on lawns and it really could use some help in the traction department.
/ R1s or R4s? #14
Thats,well,,kinda true??
AG tires don't do any better on ice than ind.,so,[bet ind would actualy do better on solid ice than ag's.???]
But either with chains would be the ticket.
Only thing I see ag's beating ind. are deeper mud and deeper snow.
On the other hand,ind. beat ags for stability,toughness,and for heavier weights,and also for not tearing up your yard so bad.Also loaded the center of gravity is lower with ind. They also drive smoother on roads.[see,told you all there was advantages!]
Your turn.
/ R1s or R4s? #15
For your dirt work R1's are the better choice hands down. I have used both R1's and R4's on snow and ice. IMHO they are both very poor snow/ice tires. The R4's are a tiny bit better on snow and ice but not enough to influence my dirt working decision. The R4's don't tear the yard up as bad as R1's when mowing. The R4's wear like iron but ride like iron also. R1's ride better. R4's are also more puncture resistant. There is no perfect tire. For snow and ice I would recommend chains on a tractor regardless of tire type. I use an ATV with a blade to push snow. That's what works best for me.
/ R1s or R4s? #16
Get what is best for 90% of the work you do. The rest of the time you will just have to live with your decision.
As for R1's tearing up the yard I have not seen it in my parts. Been mowing with R1's for 6 years and no issues unless its wet. Guess its the makeup of our clay soil.
Chris
/ R1s or R4s? #17
I only had R1's once and vowed never again,, for one,, it is what one is used to, When you run Deere hoe's year in and year out, not much choice but R4's. The L 48 I have now has to have the 4's because of our geological make up here... R 1's get tore apart pretty quickly because of the rock, constant shale, outcroppings, granite forms and other rock protrusions, So for longevity, I like the 4's.. If our ground was much different then I would consider others... Check and see what the popular tire use is around your neighborhood, this should give you a pretty good idea.
/ R1s or R4s? #18
Chris
I think that the R1s tearing up the turf story is a fable with the smaller tractors.
/ R1s or R4s? #19
It ain't no fable,look at the tires,[thats why r1's are better in the mud],now if your yard is not real soft,than...
/ R1s or R4s? #20
Nah, LBrown is right. The little BXs dont tear up turf noticeably. Even when wearing AGs.
larry
2018 Club Car Carryall 1700 4x4 Diesel Utility Cart (A61572)
2018 Club Car...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
JCT 72" VIBRATORY ROLLER (A64281)
JCT 72" VIBRATORY...
Caterpillar 143H/163H Motor Grader Service Manuals (A63117)
Caterpillar...
1999 GENERAC 99A GENERATOR (A64280)
1999 GENERAC 99A...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
