BX24 Flow rate
/ BX24 Flow rate #1
Aquaman
At the end of Smakadeer Rd. in WestCentral MO
Kubota BX24
I'm sorry to ask this because I'm sure it's been discussed but I can't seem to find it searching. Does anybody know what the flow rate is at the power beyond on the rear of a BX24? Will be running about 3000 rpm. Thank you:eek:
/ BX24 Flow rate #2
If my memory serves me right, its somewhere 5.5 gpm. Geez, I gotta get one of those shop manauls with all this info.
/ BX24 Flow rate #6
The total GPM for the BX24 / 50 series is 6.3 GPM (I'm looking at a brochure), but approx 2.6 is dedicated to power steering, so the available GPM to the FEL, 3PH or remotes would be only 3.7. Can't find the exact GPM for power steering, but those numbers should be very close. (The power steering GPM is not broken out in the brochure or owner's manual, but I've seen it somewhere.)
/ BX24 Flow rate #7
That sounds close...some amount of the total flow is dedicated to the steering with a priority valve.
/ BX24 Flow rate #8
After reading three different sections in the WSM, here's the complete story...
Total output at pump 6.2 GPM @3200 RPM. Flow priority valve allocates constant 2.5 GPM to steering...so, remainder (3.7 GPM max) goes to implements. I apologize for not doing enough reading first time around...:(
/ BX24 Flow rate #9
Thanks for the correction. Know we know.thanks for helping out .:cool:
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2023 KOMATSU D51EX-24 CRAWLER DOZER (A65053)
2023 KOMATSU...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
TRUCK RAMPS (A64556)
Landhonor ATS-RT12R Mini Excavator (A66285)
Landhonor...
2015 Global M3 Street Sweeper (A64556)
2015 Global M3...
