It's broken HELP
/ It's broken HELP #21
When mine broke in the same place, opposite side I did not try to put the part back on. Like I said I put in studs instead of using bolts and then used JB Weld to reform the void area. Has been that way since 2004 with no issues. I also drilled and tapped two extra holes and put studs in them also. It was then secured with washers, lock washers, and nuts.
Chris
/ It's broken HELP
Kub top link bracket repair
Ok let's see if I can comment on some of the great replies and at the same time explain what we have done.
Scott vt. A welder confirmed what I remember from an old heat & beat class the cast iron is not the easiest thing to weld without warp/crack . Also concern re: seals and gaskets getting too hot. Nope it's not the way it was coming from the factory. Old saying,"everybody drives a used car."
Two bit score- you'll see JB weld in the details.
Polo1665 - afraid deeper drill / tap might penetrate the oil res.
Dqdave1 - did not choose to try drill / tap
DanD78 - see above did not want to weld
Diamondpilot - I'm not sure what broke mine, I had been using the PH but the chard was a little rusty so must have been earlier.
Duh, I need to pay closer attention when modifying. Keep reading
Firemanpat2910 - thanks but I choose to stay away from welding on that part.
Sandman2234 - I have access to a part time machine shop so you'll see what we did
Sackett2 - used part of you solution.
Wayne H - Old tight wad here - and not confident mechanic - was guestamated labor $250 still have to get new seals etc.
greenmule - thanks for your input.
Valley - removing to weld ? See above
Akfish - Old tight wad here - and not confident mechanic
Cocre - you reaffirmed my memory (50 years ago)about heating cast iron before welding
tommu56 - that is close to what I did.
Polo1665 - going to see if the plate with three good bolts works
kcarl - thanks, more confirmation re: pre-heat cast iron
Now if I haven't worn out my welcome here is where it stands now and a brief description of what was done.
Found a 1/2 " steel plate almost the right size.
Had to nip corners and then remove 1/4" on one side.
How do you like my combo wood/metal radial arm saw?
Took many passes to cut. Did not even get too hot to touch.
I know it's a mess, but if I didn't save stuff I would not have had the 1/2inch plate.:D
Cut wooden spacer to clamp between the brackets for welding NOT good idea.
Wooden spacer let the brackets move when welding and holes were too far apart.
Back to milling machine. Elongate holes 1/8 inch to sides.
Purchase 4 new bolts 1/2 inch longer & 4 lock washers.
Now I know what caused the break. When I added TnT I did not check clearances close. The top cylinder was forcing the brackets apart. Your can see the evidence in the picture. I have cut out a little extra now and the top cylinder does not touch when lifted to the max.
So dear friends, when you start mixing and mis-matching be sure to check all movement from one extreme to the next.
JB weld broken chard back in place with bolt covered with paste wax to keep JB out of threads
Tighten bolts in three unbroken holes then tighten bolt in JB welded hole just snug twist of the wrist. Had used 4 minute JB did hold.
Hooked up the tiller with the three bolts holding and looks OK for now.
Thanks again for all your concern and replies.
/ It's broken HELP #23
very nice and well thought out.:D now lets pray it holds.;)
/ It's broken HELP #24
Now I know what you were fixing!
The fix looks good, watch it for stress crack, it will show you if there is a weak area that needs to be addressed.
/ It's broken HELP #25
Afterthoughts:
When using a miter saw for cutting metal I have used a smaller diameter abrasive blade than normal. Found this was much easier on the saw. :D
Of course I'm late as usual.:(
/ It's broken HELP
Afterthoughts:
Yep, I started with a 7 1/4 blade on my old 10 inch radial arm.
And...."Better late than never."
If anyone is still following this. I now remember that when I first installed TnT the top was mounted in the TOP hole of the brackets. It cleared there.
I caused the destruction when I made the mistake of using the BOTTOM hole.
Don't remember which implement was being changed, but the lift arms were blocking the top hole.
/ It's broken HELP #27
Good Mornin Norris,
Well it looks like you used what you had and were quite resourseful ! I personally thought welding on there without complete dissasembly was not possible but of course Im no expert !
Hopefully this fix will work well for you, good luck with it ! :)
2018 JOHN DEERE 325G SKID STEER (A65056)
2018 JOHN DEERE...
2012 PROCCO 130BBL (A67714)
2012 PROCCO 130BBL...
PORTA POTTY (A67714)
2009 FORD F-750 SUPER DUTY (A67714)
2009 FORD F-750...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
Sandblast Skid (A68134)
Sandblast Skid...
