Experts only: need Cross for Kubota Hydraulic Filters
/ Experts only: need Cross for Kubota Hydraulic Filters #1
tsterkel
North Texas
2202 Kubota
Please do not send me to a web site, unless you went there first and confirmed that it provides an answer.
Here are the 3 Kubota Hydraulic filters, from the parts manual:
38240-3771-0
38430-3771-0
30400-3711-0
thanks in advance for your consideration!
/ Experts only: need Cross for Kubota Hydraulic Filters #2
Just curious, but why bother? We all know what the wrong filters and fluids and other parts can do if they are not the EXACT part. Saving $3 can cost alot in the long run.
/ Experts only: need Cross for Kubota Hydraulic Filters #3
I used the Wix filter site to get the equivalent oil and hydraulic filters for my B2400. Just type in your original equipment part number and it gives you the Wix eqivalent.
I can get Wix filters about 15 miles closer than the Kubota dealership.
good luck
Wix was the site I used, and was the motivation for requesting that I not be sent to sites unless you know that it works for my equipment. Sorry
any experts?
/ Experts only: need Cross for Kubota Hydraulic Filters #6
Perhaps you should contact them then.... After all we are all experts in our own minds:D
/ Experts only: need Cross for Kubota Hydraulic Filters #7
Wow..asking for "expert" advice from a bunch of anonymous people on the internet is worth exactly what you paid for it.
Yes I AM an expert and the Fram PH8A will work perfectly in your application and it will even match your tractor color....:rolleyes:
PH8A for the HYDRAULIC Filter? Please confirm, as that is a very common filter, and I can get crosses to my favs, Wix, Donaldson, and Baldwin!
/ Experts only: need Cross for Kubota Hydraulic Filters #9
Go to the Napa site, you can type your numbers in there and get the cross
reference filter..These are the ones I have been using
Not an expert
/ Experts only: need Cross for Kubota Hydraulic Filters #10
Yep the Fram PH8A fits everything:D I was yanking your chain.....made my point about internet experts though:cool:
good yank.
nearly got this worked out for myself. Took the old filter, confirmed thread, used micrometer to measure gasket ID/Od, and metal OD. and got the R values. getting there.
/ Experts only: need Cross for Kubota Hydraulic Filters #12
Hopefully when you finally get there, there will be no need to come back. You have teebagged a few good people here.
Dave
/ Experts only: need Cross for Kubota Hydraulic Filters #13
Dave
Well said Dave,
50 acres, carbon negative sustainable farm , he's all carboned out. we should go easy on him.
/ Experts only: need Cross for Kubota Hydraulic Filters #14
Expert- Someone who knows more and more about less and less, until they know absolutely everything about nothing.
/ Experts only: need Cross for Kubota Hydraulic Filters #15
Go to NAPA. They have cross referenced for both my Kubota B8200, and my 1941 Farmall "A".
Tisco cross references both of my tractors too.
Otherwise, got to Kubota direct. There's even a couple dealers here on TBN. Carver has been great to work with in the past.
And, ask nicer...
38240-3771-0
38430-3771-0
30400-3711-0
/ Experts only: need Cross for Kubota Hydraulic Filters #16
While I would probably feel ok using a WIX or other filter for the hydraulic circuit filter I think I would only use Kubota for the charge pump Hydro filter as even the Kubota ones have blown out. You need to match media size and flow quanity, thread size and pitch, diameter of base and the most important is the drainback valve and pressure relief valve settings.
David Kb7uns
/ Experts only: need Cross for Kubota Hydraulic Filters #17
http://indianpaintbrush.com
50 acres, carbon negative sustainable farm,
in process. Also, trying to break even in
5 years or less!
Just wondering, doesn't a Kubota Tractor create more carbon (carbon monoxide)? Wouldn't a horse and plow be more carbon negative? But, only respond if you're an Expert.
Also I believe the web link "http://indianpaintbrush.com" is not functioning, that is, it's Not Sustainable. ;)
/ Experts only: need Cross for Kubota Hydraulic Filters #19
I can't get the link "http://indianpaintbrush.com" to work either, was kinda curious about it.;)
/ Experts only: need Cross for Kubota Hydraulic Filters #20
Dave
Well said indeed!
Rhino HPHD 3pt Auger (A60462)
Rhino HPHD 3pt...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Trailmobile Van Trailer (A61307)
Trailmobile Van...
Allmand Maxi-Lite Sho-HD S/A Towable Light Tower (A60352)
Allmand Maxi-Lite...
