dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,772
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
Like Mike said you should secure your pins so they don't turn. Here is a pic of the same location on my backhoe. You can see the bolt in the one bushing that secures the pin. You could just drill through at one of you grease fitting locations and add a bolt. Mine also has gussets to prevent the side plates from spreading, this is a common problem on some of the cheaper backhoes.
Interesting pix, Frank.
I have never seen a backhoe that uses a shared pin for 2 of its cylinders.
One has a clevis-end and one had a cross-tube. The problem with that is
the clevis-end cyl is not greasable with a zerk fitting. Is that a Mazzotti?
I have never seen tie-rod cyls on a hoe, either, BTW.
