Can someone fill me in on this B7100 info?
   / Can someone fill me in on this B7100 info? #1
grossgary
midatlantic
1994 Kubota B7100 HST 4WD
Could someone snap a photo of the left side B7100 MMM connections? I have all the owners manual, for the B7100 and the 60" mower RC71-60B.
I can't make sense of the connections for the mower to raise/lower on the left side (as sitting in the tractor). There's more connections on this side and they aren't as intuitive. The owners manual was a bit ambiguous.
   / Can someone fill me in on this B7100 info? #2
Gary, I can't take a picture as the tractor is no longer here but from memory on my B7100 There were three attachment points. Pins on the back on both sides and then the front lever connection. The back drag arms on the mower sub frame have to be be release from a pin to fall down. Hope this may be of help. :D
My biggest problem was always getting the short drive shaft on the mower and tractor splines.:D
   / Can someone fill me in on this B7100 info? #3
See if these pictures will help. My mower was for a B2400, but I adapted to fit my B7100. I think the mounting brackets are the same.
that's not the issue, i have it all hooked up and used it last summer, i realize where all the attachment points are.
this is the issue, the "pins" on the left side. there isn't just one pin/hole/bracket (the other side and front are easy and straight forward).
it's like a bunch of arms, links, holes, and pins back there to connect on that one side. since there are multiple items and the manual only uses words it's kind of ambiguous which ones it means.
i've played with a few arrangements and i just need to get it right and see how it goes.
   / Can someone fill me in on this B7100 info? #5
As I recall, the inner arm on the right side crosses over and attaches to the left arm near the pin. The two are loosely held together with a shoulder bolt that allows a small amount of articulation. The snap pin from the deck only attaches to the left arm itself, not thru both.
WOW, thanks a bunch, that should do it. My B7100 manual sucks compared to that, it has no diagrams - just lots of confusing words that don't really distinguish between all the various rods, connections, bolts, holes, pins and stuff.
How hard was it to retrofit thhe B2400 mower to your B7100? I'm looking for another used mower for mine and a B2400 series is probably easier to find.
   / Can someone fill me in on this B7100 info? #7
Will this help, it's a B7100 with an RC60 deck. Sorry it's covered in rubbish but do'n't always have enough time to clear it out.
If this isn't clear enough I will be where the tractor is next Tuesday and will have it clean by Wednesday so can email other photos. The setup looks completely original.
Jamie
Jamie - wow that's even more interesting. i would indeed like a lower shot of that side and one of the other if you can.
It seems like mine is a different set up. I have a B7100 with 60" deck as well and the deck looks the same but mine isn't attached the same way. i don't have that long arm sticking out the side and attacked to the front of the mower deck. those front attachments aren't used on mine.
Does yours have a FEL or BH? (front end loader or back hoe, or any other attachments)? Maybe the mounting is different for those configurations?
More complicated...ah!!
   / Can someone fill me in on this B7100 info? #9
I'll do that next week then Gary, it's no problem.
No there are no other attachments at all as it was set up only to mow lawns. In the UK FELs are not used as they appear to be in the US, guess nowhere near the acreage or the oportunity to create major projects on your land. The loaders are often used by people with horses here, but that's not so many. I would guess that maybe only 1 in 10 or 15 compacts have a loader here.
Until Monday I'm in the UK, but on Tuesday evening I'll be where the tractor is in France, it takes us a day to sort things out when we arrive so I'll try to get that done for you on Wednesday.
Jamie
   / Can someone fill me in on this B7100 info? #10
Gary, can you post a picture of your set up. Maybe someone will be familiar with what you have.:D
   / Can someone fill me in on this B7100 info? #11
Gary,
My 1996 B7100 HST has a RC60-71B deck, did you just get the numbers reversed ?
I'll be happy to send you pictures of the left side as soon as I get a few free minutes. We might be neighbors, I'm in Grafton,WV. If that's close your welcome to stop by and look. Let me know and if needed I'll take a few photos and send them.
Casey
yes, that's the same deck I have.
awesome - I'm in Morgantown, so we are neighbors. my schedule sucks now since i'm working full time and watch our daughter while my wife works but I would love to spin down there and have a look at it. that would definitely work.
i guess we should PM some phone numbers or email addresses, what's the best way to get in touch with you?
Looks like Mr. Whitty and myself will get together some time and sort this out. Thanks!
I was going to take a picture and post but the camera batteries were dead, that thing is a hog.
   / Can someone fill me in on this B7100 info? #14
Here are the photos as promised...
thanks a bunch biffo, something is definitely up with mine. oddly enough it does "work", though i don't know how. the mounting hardware looks completely different than that, wonder if a previous owner just made something for it.
   / Can someone fill me in on this B7100 info? #16
Grossgary -
I think Biffo has a different mower with a much different mounting system. My original B7100 mower, Model MR6000 used that mounting. I think they called it parallel linkage. I don't know the number of Biffo's mower, but the later B7100's had a RC60-71B, I believe. His mower appears to be a model they offered in between the MR6000 and the RC60-71B. I put the RC60-B on mine even though it was made for a later model tractor, I think a B2400 if I recall correctly. It was not too difficult to mount. The biggest problem was fabricating the rear mounting brackets. The front hanger bracket pretty much bolted on with only a few modifications.
The older parallel linkage mounting had a tendency to wear a lot. With it the mower was actually pushed by the parallel linkage, whereas the mower is pulled along from the front mounting bracket on the newer mowers. What I miss most from the old MR6000 was the height adjustment lever. It was much more convenient than adjusting each wheel separately as on the newer models. The newer mower cuts better also.
I also put a separate cylinder on mine to raise the mower independently from the 3 pt. hitch. I just turn the valve under the seat to operate either the mower lift or the 3 point. I had a 3 pt. grass catcher on mine, and that was the only way I could raise and lower the mower without the hitch going up and down.
I have since transferred the catcher to my John Deere. On it I took the lift arm off and replaced them with chains. That way the 3 pt. hitch arms hang from the chains and do not go up and down with the mower. I don't use the 3 pt. for anything else on the John Deere.
Here is a photo of the MR6000, but I can't get it to come through very good.
   / Can someone fill me in on this B7100 info? #17
The deck model number is RC60-71HR with a serial number of 10705.
I believe the mower to be from the late 1990's or later but not too sure on that, the tractor is from the 1980's.
The fact that it's a UK tractor and deck shouldn't make any difference should it? I can't see why when model numbers tie up.
If you need any other detailed photos just shout, it's no problem.
Jamie
Thanks guys, I'll have to look into this, mine is obviously different than that, but maybe it's not wrong? I'll try and post a pic.
PARTS ONLY - Has Title - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - Has...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
John Deere 50 (A60462)
