Firefighter Kubota
Finally installed my rear remotes and hydraulic top link...Thanks to those who provided direction and helpful pictures...
The prince valve was larger than I had planned but worked out ok..Didn't like the grey so I painted black.
Torched and welded the bracket myself.
1/4 lines to the front provide plenty of flow. They now control the plow angle, no more getting on /off the tractor to adjust it...They are of course QC there so I can run a grapple in the summer. Thats next to buy...
Still need to weld up a bracket to hold the forward QC's.
The rear I installed a hydraulic toplink. I needed to angle the rear blade up when loading into my dump trailer, and doing it by hand was a PIA
The new top link along with my pats easy change makes connecting to implements a quick job...
I also kept my "rear hydraulic loop" for the log splitter, using a PB on the valve. That uses 3/8 lines. everything else is 1/4 lines.
The valve controls are just behind and below my R shoulder and I can easily reach them with my right hand. Not a convienent location if they were being used as often as a loader, but for my use thier location is fine..
here are the pics...
